Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer does not stop filling up with water. second time basement flooded.
  • 5,911 Answers
The water level is controlled by the pressure switch which is located behind the load level selector knob on the control panel. Before assuming you have a defective pressure switch, however, read the following link:
http://www.fixya.com/support/r762094-washer_overflows
In many cases the small air hose on the pressure switch can come loose from the pressure switch and cause the symptoms you are experiencing. Check the air hose to ensure it is still attached to the pressure switch and check the electrical connections to ensure they are not corroded. If the air hose is intact, check the entire length of the hose from the pressure switch to the air dome on the wash tub to ensure it is not leaking anywhere. The air hose is how the pressure switch senses the pressure differential as the wash tub fills. Without it, and the pressure switch will not work. If you need to gain access to washer interior, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the consoleWasher does not stop filling up with water. second - 2.gif.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If these preliminary measures do not work, replace the pressure switch. If the pressure switch requires replacement, you can search for the best price at these web sites:
repairclinic.com
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Oct 05, 2009
Will not spin or agitate
did the washer cause the flood? you could have got water into the motor if it was above a few inches deep. do you hear the motor working, and no agitator movement? will it fill ? or is it just dead?
Nov 10, 2013 | GE Profile WPRE6100G Top Load Washer
Water leaks past the water pump filter gasket reseating the filter does not stop the leaking lg tromm Front Loading Washer
I regularly clean my filter of slime and debris (after not even realizing this needed to be done and having my pump give out of me). TWICE I have awoken to a flooded basement due to leaks in the filter area:
The first time, the plastic stopper was not in the small rubber drain hose properly and had popped off.
The second time, I had cleaned the gasket, inserted it tightly like I always do, and awoke to another flood! I thought perhaps the rubber gasket on the filter was on wrong, but it was fine. I inserted it tightly several times and water still poured out! It turns out there was a small stone lodged in the thread of the receiving end of the filter causing there to be a bad seal. Lesson learned. Another $2000.00 worth of flooring ruined.
May 15, 2010 | LG WM-1832C Front Load Washer
F21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Wo'nt stop filling with water and overflows.
If it fills with water while the machine is off replace the water inlet valve.
It is only overfills while machine is on, check the water level switch and the plastic tube going to the water level switch. The tube may be pinched or have a hole it it.
Apr 05, 2009 | Kenmore 23822 Top Load Washer
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
We just had a flood in our basement and our Whirlpool Duet Sport HE front load washer is displaying F28 which I know means something electrical. Is there any way I can disengage the electronics to get the...
Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock
Jun 08, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal De
