Question about Dryers
Roper electric dryer does not heat. Is there a thermister and if so where is it located
  • 5,911 Answers
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please post back with your complete model number so that I may be able to provide you with better assistance. I hope you find this information helpful.
Posted on Oct 05, 2009
Roper Electric Dryer...model RED4440XQ0 will not heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | Roper RES7646KQ Electric Dryer
My roper dryer REXEW1 runs the cycle but it dosen't heat. how di I fix it?
This is usually caused by a blown thermal cut-off located on the top of the heater housing. It blows and cut power to the heating element when the high-limit thermostat fails. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Roper REX3614KW Electric Dryer
My Roper Electric Dryer is not blowing hot air plus the timer is not moving. What could be causing this?
timer motor(wires burnt or contacts) located in the upper back of dryer. here is a website that tells how to test, it is on the bottom of the list. Good luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Roper REX4634KQ Electric Dryer
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Dryer (Roper, electric) won't heat
Its probaly gone open circuit, however there is a thermistor that prevents it shorting out, you need to locate it and test it with an ammeter
Mar 25, 2010 | Roper REX4634KQ Electric Dryer
Dryer won'y heat up
you either have a bad heating element or your limit switches are out..it could be either or both they are what control the heat
Jan 27, 2009 | Roper REX3614KW Electric Dryer
Dryer not Heating
Take the bottom front panel off and the thermal fuse is mounted on the blower duct near the thermister
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
Roper electric drier will not turn off or heat happened suddenly
Replace the heating element. Located in the backside of the dryer
Jan 04, 2009 | Roper REX4634KQ Electric Dryer
Not heating where is the model number located on roper dryers?
model #s are located on panel inside of door. check breakers, heater and thermal fuse always disconnct electrical power
Dec 13, 2008 | Roper REX4634KQ Electric Dryer
My roper electryc dryer will not heat
I always like to check the heat relay switch. I had that problem with my dryer and that was the solution.
Jun 29, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
