Question about Kenmore 24432 Top Load Washer
Spins with little weight
Good day
my clothes are still full of water after spin cycle water does drain and does spin when i devide wash in half there is some leaking of oil slattered around the inside shell of dryer,
mark
  • 833 Answers
Blown transmission seal. Get help for this.
Posted on Dec 22, 2007
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
My whirlpool duet washer spins but cloths still damp after full cycle stop.
I have the same washer and it will do this if I have put a load of clothing that is not even in weight for example I washed sheets with a heavy blanket and I then had to run the Drain Spin cycle. Hope this help
Sep 06, 2009 | Washing Machines
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Can you add clothes to washer after cycle starts?
Not really. Even if it lets you it will pump out the water first. This kind of defeats the purpose. If it didn't pump out the water it would spill on the floor.
Jul 03, 2008 | LG WM2688H Front Load Washer
Kenmore 24432 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
