Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Electric Dryer - White-on-White
Problem for Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus...
My whirlpool duet electric dryer needs several
By darcyt10 on Oct 05, 2009
My whirlpool duet electric dryer needs several cycles to dry normal load of clothes, dryer is 6 yrs old. Is it the heating element or could it be something else?
Solution #1
posted on Oct 05, 2009
Somewhat Helpful)
petersfan761
Rank: Wiz
Rating: 85%, 33 votes
Initial reaction is yes, probably.
Second guess would be the switch.
The switch tells the dryer what to do, and if the heating element is good, it will do it.
Test the switch quickly first, and if it checks out, look at the element.
Was this helpful?
Yes
No
Solution #2
posted on Nov 05, 2009
Not Rated)
madonnac
Rank: Apprentice
Rating: 0%, 0 votes
Venting issues cause 99.9% of long dry times (and also cause water in dryer).
Clean venting, or replace if it's plastic or aluminum foil.
Was this helpful?
Yes
No
Solution #3
Not Rated)
todd0708
Rank: Guru
Rating: 87%, 90 votes
if its hot,the element is probably ok,seeing how old it is ,and im assuming its worked well for you,the first thing i would do is un plug it pull it out from its spot and clean it ,check vent for lint buildup,remove back of dryer,fan and dryer lint holder areas get built up with lint paper and whater ,was left in your pockets,make sure the are clean,element then can also be tested with continuity setting on volt meter,most of the time you can see the damage in the element without a meter,if you have never taken a dryer apart before,i reccomend finding a friend with some mechanical skills to help,be carefull ,always unplug it first,hope this helps,aloha from maui todd0708
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Duet 7.0 Cu. Ft.
Questions and Unsolved Problems for Whirlpool Duet 7.0 Cu. Ft.
Do you recommend Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super Capacity Plus Electric Dryer - White-on-White?
Answer
Answer
new whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Answer
does not start. power is present at power connections
Answer
Dryer Duet model GGW925oPWO Started to squeak and continued squeaking throughout the cycle. First... (More)
Answer
I think there are coins stuck between the drum and whatever surrounds it. How do I get them out ?
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in Van Nuys, CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
