Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Danby Designer Dishwasher sprayer arm stopped working
My Danby freestanding dishwasher was working fine until today. It seems to do everything ie. go through the cycles, pump water in/out except that when its running the sprayer arm isnt working at all. Does anyone know how to fix this?? Thanks.
  • rustneversle Oct 05, 2009
    Sorry, it is a countertop dishwasher.
    No. When I turned it on earlier there was something in the way and I moved it.
    The sprayer arm was working for a few minutes but when I came back I could tell something was not right because of the lack of noise.
    Thanks.
    Problem Solver:
  • 5 Answers
Is anything in the way of the arm? Sometimes you can't see an item sticking down too low ... interfering with the spinning.
Posted on Oct 05, 2009
Have a whirlpool GU2400XTPT1 undercounter dishwasher for the past 5 years. Has worked perfectly until a few weeks ago the glasses and such on the top rack haven't been coming completely clean. Everything...
have you change you dish soap -to a phosphours free agent there has been rumor that these new cleaner will leave residue on glass.you can alos make sure the the dishwasher is clean after time they can build up lime and scale,calcium you can use any kind od dishwasher cleaner this may help
Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Indesit idl 705, tablet not dissolving and crockery still dirty, was working fine. Sprayer arm seems to not rotate freely
Clean EVERYTHING and ensure it's assembled correctly.
The sprayer arms have an unlocking ring and can be rinsed, the filters must be washed and rinsed and properly reassembled.
Even cleaning the door seals can help.
Test again, clean again (as more muck can be circulated).
Sep 27, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
Water not flowing into Danby 18"
Okay, this might seem crazy, but it worked. I spent the last 2 days trying to contact Danby customer service to no avail, so I came back here to look for solutions. Found two:
(1) Someone said to open the little rubber cover under the front right of the machine...I couldn't find such a cover.
(2) Someone said to pull off the front plastic panel...mine doesn't seem to be removeable.
So! I turned my Danby DDW1805 upside-down (!) to see if I could locate the aforementioned rubber cover, and a bunch of water drained out of the machine. This is what both solutions above said I wanted to happen, so I flipped it back right-side up and hooked it back onto my faucet.
Golden. Works perfectly again.
May 15, 2009 | Danby DDW1805W Designer Series...
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Danby DDW399W dishwasher - drainage and spin arm problems
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Nov 19, 2008 | Danby 22 in. DDW396 Free-standing...
Dishwasher not cleaning/water sprayers not spraying it appears
I had the same thing recently. Everything appeared fine mechanically, but no water would spray. I inspected the bottom arm as closely as possible and actually found a half melted clear plastic straw inside of it. 30 minutes, tweezers and a small pick eventually got it out and all is fine.
Sep 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
254 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
