Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hose The intake hose has torn apart at the base where it is attached. Is there some way I can repair it or do I have to order a new hose. The Sears store where I purchased it is of no help.
    President:
  • 1,673 Answers
You will have to replace the hose. If you want to get it thru Sears, go to Sears.com, click on parts, enter the model number, if they have it in their system, you can find the part there and order it. Or take the model number and go to where someone has Hoover parts and buy it thru them.
Posted on Jan 10, 2008
Shark Navigator repair manual
Take your Navigator to a repair shop and have the hose replaced with the new one.
Jan 05, 2017 | Shark Navigator Bagless Upright Vacuum
Take handle apart
Duct tape fixes most things and a hammer the other things :>) In your case Duct Tape for a quick fix or Google
make model replacement hose
Jul 18, 2016 | Vacuums
The hose on my spot bot has torn
yes you can replace the hose for $25
If your unit is less than a year old it will be under warranty and replaced at no charge to you
Dec 15, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Part of the hose is torn. Do I have to replace the whole hose or can it be repaired ?
Which hose is torn? The hose underneath or the hose with the extension wand in the handle?
Where I work we can sometimes repair the wand hose, and the little hose undernath is usually a cheap costing replacement.
Dec 04, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hose has a break
Don't cut the hoser. It has electrical wiring. You will need to replace it. Unfortunately, Samsung doesn't make vac's anyore. you might find a repair place that can fix your hose, or can order a new one. . we can fix it here, we are in Albuquerque, NM. I hope this helps.
Jun 05, 2009 | Samsung Quiet Storm 9048R Bagged Canister...
Progressive with Direct Drive not picking up
check and see if your brush roller is turning.remove the hose and see if you have suction.if not then you have something stuck in the suction intake. after removing the hose turn it on and put your hand over the hole wher the hose was connected to the base.if there is suction there then you have a blockage in your hose.if thats the case take the hose completely off the vacuum and take it outside and blow it out with a garden hose.if the blockage is in the intake then get a coat hanger and bend the tip so it is round,then work it down into the hole where the hose was connected to the base.you should be able to push push out the clog through the bottom.also clean all the filters real good.you can also take the filters out and then turn it on if you have suction then ,then its the filters
Dec 29, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Torn Hose
HI.
You can use evo stick glue.
But normally once it has ripped open it will do it again so probably best option fit new hose.
http://dysonmanuals.inc.io/
Chris..
Nov 03, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
83 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
