Question about Lexmark T644 Laser Printer
I am getting RIP software message.. What should I do. ?
  • For Old Hack May 11, 2010
    Really! Try printing the words 'Test' from Notepad
  • 320 Answers
Remove the boards one at a time untill you no longer get the error to isolate which board is causing it. any one of the boards can create this error. this usually points to a corrupted nvram chip. but it can also be caused by dirty contacts on the boards. once you isolate the board thats causing it clean the connctions and see if that solves the problem if not replace the board.
Posted on Nov 01, 2009
  • norman steach Nov 03, 2009
    ant one of the boardss in this printer can give you this error it is a software communications error, this can be cause by dirty contacts on memory simms.engine , logic board, or options cards, to isolate which one is causing the error turn the machine off and remove the boards one at a time untill you no longe get the error. cleaning the contacts might cure the error if it doesnt replace the board
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
My Dell M5200 printer says 900 Service and RIP Software. I have restarted it several times and checked the menu - all looks o.k., but it won't print. It sounds like it is going to and then the above...
900 RIP error message is a generic error.
In order to understand when it's coming from you have to give more information.
Does it happen when printer is printing a job from a PC, or when it just stands alone idle?
In first case it's probably a job that is generated by the driver which cannot be properly "digested" by the printer. In this case, press select and return on the OP as soon as you get the secondary code message and write it down. Then call Dell support and tell them about it.
If the printer is getting 900 RIP error when being idle, I'd recommend disconencting it from the network for a couple of days to see if the error appears. If it doesn't, then it's something from the network which is causing the problem. Perform the same procedure of collecting the secondary code and contact Dell.
If it still gives 900 RIP error when disconnecting, then it's one of the hardware part which is causing the problem. It might be an option such as a drawer, or a memory unit, or just a main board. try disconnecting one by one the options and see if the problem goes away. Whenever it comes back, collect the secondary codes.
hope it will help, dont forget to thumbs-up
Nov 15, 2010 | Dell M5200n Laser Printer
Erro code 900.00 service RIP soft ware. What is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dell 5310n: error message is 900.00 service RIP software A few of my users were having trouble with a Dell 5310n printer. The error message on the display was error message is 900.00 service RIP software. When printing large data files, such as a PowerPoint presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the print jobs and send them directly to the printer. This seems to have corrected the issue so far.
Since I have HP printers on the same print server and none of them have had any kind of issue printing the same large files, I starting to think that the problem is due to either bad printer hardware or print drivers from Dell.
http://itadmindev.blogspot.com/2008/07/dell-5310n-error-message-is-90000.html
Feb 03, 2010 | Dell 5310n Laser Printer
Erro code "900.00 service RIP Soft ware. What is this?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what I foudn working on the same problem....
Printer won't print document and is getting the message 900.43 Service RIP Software
this is a software communication error and can be caused by any one of the boards in the printer. start with the options cards and remove them one at a time untill you isolate it to the one that is causing the error.
Oct 29, 2009 | Lexmark T640 Laser Printer
When i got my rca mp3 the easy rip software was able to open.
If you have upgrade your computer after it was busted, that could cause your old version of the easy rip software to not recognize your rca mp3. what you'll prob need to do is update the easy rip software.
Aug 17, 2009 | RCA M4208 MP3 Player
I have a Xerox Docucolor 12 printer which uses a RIP to process files you send from your computer in order to print them in the Docucolor. The RIP model is Splash G640 in an Apple G5 power pc. I have...
get the cables checked and replaced if still the same problem.the software which you are loading from internet are missing some files
the orignal software from xerox is required.
Jul 19, 2009 | Computers & Internet
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
May 04, 2009 | Dell Office Equipment & Supplies
Error message on lexmark printer
900 Service RIP errors are usually a firmware failure. Upgrade to the latest firmware from Lexmark. This link is for the C52X network model:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Aug 07, 2008 | Lexmark C522n Laser Printer
Loading songs - format message
if you've used wmp to rip and encode the cd to the wma file standard, the ipod won't play them. the ipod doesn't support wma or ogg vorbis (and doesn't support the pro part of mp3 pro) you need to encode your files to either mp3 or aac (or leave them as wav files, though these are very large) for the ipod to play them. this may be causing the mmjb transfer problems.
check out the software compendium on info on alternatives to rip, encode and transfer to the ipod.
Jan 09, 2008 | Apple iPod shuffle MP3 Player
Lexmark T644 Laser Printer Logo
101 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
