Question about Sony Cyber-Shot DSC-T5 Digital Camera
My camera doesn't recognize that the camera lens cover is open so I can't take pics. The power turns on and I can still scroll and view the saved pics I have on the camera. Can this be repaired?
SOURCE: Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Posted on Apr 19, 2007
SOURCE: Turn on the camera, cover lens is closed even though i already pull it down
if you open up your casing you will find that almost dead center on the front PCB, just to the right of the battery at the top of the empty battery area there is a box. possibly with some plastic fragment that is broken off. if you touch inside this box w/ something conductive it will think the lens is open. You can either fix this area or permanently solder it so it thinks it is always open. You can still turn it off using the button on the side of the camera
Posted on May 25, 2007
t00nz
  • 4738 Answers
SOURCE: lens cover won't open
Here's a fix for a Canon A400 lens cover. See if it's applicable for you:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 17, 2007
SOURCE: Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Posted on Jan 08, 2008
rotating the lens cover fixed the problem
thanx lots
xoxo
-gossipgirl
Posted on Aug 11, 2008
Dsc-P52 lens cover sticking
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Feb 24, 2012 | Sony Cyber-Shot DSC-P52 Digital Camera
I have a casio digital camera qv-r52 3x optical zoom when I turn power button on it will not stay on the lens retracts but I can view the pic's on the dish
Katie, Joe alerted me to your problem. The symptoms that you're experiencing suggest that you're experiencing a lens error. Lens errors are fairly common, but there are many causes. Some causes include poor or drained batteries. Or sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 16, 2011 | Casio Cameras
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Sony DSC-S750 can only see black on LCD
It seems as though either the lens aperture is not opening or the CCD has failed. You could send it in to us at mackcam.com for an estimate
Dec 31, 2008 | Sony Cyber-shot DSC-S750 Digital Camera
Lens Cover Won't Open
NO Super glue this can be fixed pretty easily to get fixed. most local shops will not charge you to much to fix it maybe 15 to 20 at the most i figure. or you can remove the lens cover by putting a very small flat head screw driver on the side of the lens and with the camera off pull away from the camera and it should just pop off. Superglue if you get it on the lens will rune the whole thing. Just tiring to help out . I repair lens shutters all the time they are just mechanical parts nothing really special about them.
Apr 16, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Stilll not working..
Defective, optical lens assy, most probably the lens cover mechanism, but its integrated in the entire lens assy. When power on, observe the lens cover if will retract or open, if not, then thats it.
Aug 26, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
Camera Motor running
your lens is possibly damaged or seriously out of alignment - replacing lens is easier , than opening the camera ( hard to believe how many tiny screws etc . are in the way ) plus if you do open it . . . ? few technicians will work on it , after .
Aug 08, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Lens Cover Closed
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Sony Cyber-Shot DSC-T5 Digital Camera Logo
12 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
