Question about LG DLG8388 Dryer
LG DLGX8388 Dryer LP conversion
I've converted many appliances before but... the first step in the instructions for this model is to "disassemble the dryer". How do I do that? I don't want to take apart more than I have to....
  • shepp227 Jan 20, 2008
    I live in an extreme part of the country, far from service persons, anybody have any tips on opening up the DLGX8388 Dryer for an LP conversion...
  • big shoe Feb 03, 2008
    the method was posted on this site.(lost it) keep looking. i,m going to tackle mine today. l've done the conversion on my last two dryers no problem . but this one seems to be more involved. i'm still looking for confirmation on the close the change screw on the regulator as directed on my instructions with the kit'.i'm starting to somewhat regret getting lg's because nobody seems to want to to touch them around here. good luck
I noticed there wasn't a response, did u figure it out on your own, I am currently in the same position...
Posted on Jan 20, 2008
How do I convert a gas dryer model # (DLG2302R) to LP ? Does the required Installation kit come with the unit upon delivery
Here is a link to the conversion kit you will need. It comes with the instructions you will need to do the conversion to LP gas.
Dec 01, 2010 | LG Dryers
I have a LG model# DLGX2502V gas dryer and I want to convert this dryer to LP. Need to know where to locate gas valve and how to get to it. Also steps to take to do this. I have already purchased the...
I'm surprised they didn't give you instructions with the kit. Gas vale usually at floor level behind dryer. Sometimes you have to remove the lower drawer in stove it there is one and reach through there to turn off valve. After you pull the stove out I would remove the flex line and put a good plug on the valve..
Sep 22, 2010 | Dryers
Convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Jul 20, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
Convert Maytag Dryer to LP from Natural Gas?
yes it is very much necessary. the natural gas pressure is much lower that LP. it is @3.5 in, water column. The monometer is a pressure reading instrument that will tell what pressure is present at the gas source, appliance gas manifold and gas valve. Read the conversion kit instructions well. And adjust pressure according to data plate specifications. A u-tube water monometer is the best and most accurate however a standard analog will surfice. Please use caution.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Removing engine
I need to get the back off of my LG gas dryer. I need to convert it to LP. I have the conversion kit, but can't get the back off the dryer.
Nov 05, 2008 | Kenmore 65924 Electric Dryer
Lg dryer - gas
If you do not have the original orifice you will have to order a natural gas orifice and replace the LP one with it. It is just a small brass threaded part with the correct size hole in it, located right at the end of the burner. For a LG dryer it is probably part number 4948EL4001B but you should get your model number from the sticker just inside the door and order the correct part from your nearest servicing dealer. You can find LG servicer's in the US on line at
Nov 02, 2008 | Dryers
LG 6988 gas dryer conversion
you will need to get to the gas valve right front after the panel is off the orfice is in the end if the burner
Jan 25, 2008 | LG DLE0332 Gas Dryer
Lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Nov 18, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Dryers Logo
169 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
