Question about Technics SL-MC50 CD Player
Error/message F-26 displays. Unit will not fully power off and no Cd's will play at all. I do not have the user manual. It worked fine up until yesterday - was running full random with approx 40 cd's loaded... it stopped after 2 hrs and displayed the F-26 error code. I checked to see if there were any cd's stuck... it is clear. I removed all cd's and unplugged the unit... when I plugged it back in, the F-26 error code is still displayed.
  • 8,197 Answers
F26 is " communications error between CD servo IC and CPU "
Could mean almost anything. It's not a code that I can ever remember seeing
come up. May have been due to a random system screwup, but if it occurs
again, with it being Technics ( Panasonic ) I would feel inclined to suspect
bad joints on either of the two mentioned ICs
Good Luck
Posted on Oct 05, 2009
Received an error code 50c on my Dell printer
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
Thanks for all the ideas and help ; )
Apr 27, 2010 | Dell A940 All-In-One InkJet Printer
Cartridge error 50C
Hi there Error 50c
RegOk hope it works.
color cartridge.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 16, 2010 | Dell A940 All-In-One InkJet Printer
Cartride error 50c on display
Hi there Error 50c
ok ok try see if this works
color cartridge.
Oct 31, 2009 | Dell A960 All-In-One InkJet Printer
Error 50c, recieving this error when trying to print or make a copy
Hi there Error 50c
It works for the 940 it may work for the 960 too.
color cartridge.
Oct 07, 2009 | Dell A960 All-In-One InkJet Printer
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
When I try to play a C.D. on my system it gives me the following information. FRMTREAD, Error 15. What does this mean and what do I do to correct this problem? My system is a DEH2000MP S.N....
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
Jun 23, 2008 | Pioneer DEH-P2000 CD Player
Can't play CD-R on my car cd player
Hi there!
1. Have you checked the manual for that?
2. Is it working before?
3. Have you tried different CDs? are they working?
May 03, 2008 | Car Audio & Video
Error message
Check and see if there is a fuse on the back of the unit if so check it to make sure that it is not blown. Also make sure that it is at least a 25 - 30amp fuse. If that is not it the make sure you have the power wires hooked up right. See a Er-05 message means that the power that that unit needs is not there. So it will not read all cd's. It takes more power to read a burner than a normal cd. Hopefully this helps
Dec 11, 2007 | Kenwood KDC-MP228 CD Player
Jeep 10 disc changer; now only error message on dash.
I had this same problem on my 2000 Jeep GC Limited. Today I decided to open it up after looking all over the net and found no help, but spend $500.00 on a new unit. I removed the unit and used canned air inside all the areas I could. I hooked it back up and was finally able to make the CD cleaner disc work. Once that was done I loaded it with 10 cd's and it is working again. I'm so happy! I saved my hubby 500 big ones.
Oct 26, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
Playing cd's
You can find a user's manual here: http://www.ilive.net/action.php?name=200348996_UserManual-IBCD3816DT.pdf In case that link won't work, go here and select your model number: http://www.ilive.net/download.php
Sep 21, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Technics SL-MC50 CD Player Logo
152 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
