Question about Clark 's Mountain Bicycle Front and Rear Brake Cable Kit, Competition Stainl
My campy shift (right) cable is spliting/frayed and sticks out from under the shifter-OUCH!. Can I pull it out and just replace the cable itself and not the housing? It's a two year old 10 spd. Chorus model.
  • 484 Answers
Yes, you can. If you go to parktool.com and check out repair help at the top right hand of their home page, click the derailleur on the bike and it will take you to a page on the drivetrain. Select shifters and you will find road shifters about 2/3 or 3/4 of the way down the page.
Hope this helps,
matt
Posted on Oct 06, 2009
How do i remove the shift cable from a pt cruiser gt5 speed
Chrysler PT Cruiser shifter cable bushing replacement ...
? 5:28
https://www.youtube.com/watch?v=akgIKm1pQLM
May 21, 2014 - Uploaded by MotorCity Mechanic
Chrysler PT Cruiser shifter cable bushing replacement ... Part 1/2: 1999-2003 Jeep Grand Cherokee 4.0 ...
PT Cruiser manual stick shift cable bushing tip - YouTube
? 3:18
www.youtube.com/watch?v=mU0sgQn-0qw
Jun 19, 2015 - Uploaded by Justin Shiffler
PT Cruiser manual stick shift cable bushing tip ... how hard was this to replace? my right bushing is gone and ...
Shifter cable broken for the third time - YouTube
? 1:06
www.youtube.com/watch?v=MiHSkqSrsLY
May 8, 2013 - Uploaded by CJ Turner
Shifter cable broken for the third time ... Chrysler PT CruiserBrake Light Switch Replacement, Shifter Stuck .
Oct 29, 2015 | Cars & Trucks
96 chevy s10 stuck in park
Sounds like a bent linkage or needs adjustmentent.
I think there is a rod that goes from the shifter to the transmission and this will have a set-screw which allows you to set the travel distance. Sounds liike it's bent or moved. If i'ts a cable then the cable is frayed [probably near the shift stick.
Apr 21, 2014 | 1996 Chevrolet S-10 Pickup
I have Campy mirage 10 sp and the rear deraileur shifter ( the right shifter) will skip gears while shifting down 23 to 11. Often I can hear the mechanism making multiple "clicks" on a single...
I would lube everything and check the derailleur adjustments and cable tension. Some Campy chains are 'notchy/clunky' all the time. It's just the way they are. If the bike is low mileage most likely nothing major is wrong. Check the derailleur hanger too just in case you dropped the bike and bent it or something. The shifter 'G' springs will wear out before the derailleur. When the springs are worn, the shifts will be imprecise and will jump from gear to gear without shifting. One thing with Campy stuff...it DOES take awhile to break in. Unless the shifting is horribly off, I wouldn't worry about it - just ride it more - and see what happens. Mirage is a good product, I think inline with Shimano 105 stuff.
Sep 12, 2011 | Campagnolo Mirage
2001 pontiac aztek Has floor mounted shift. Won't shift out of park.
First of all, you are stepping on the brake pedal when you try to shift. Had to ask.
It could be a number of things. I have a 2000ish Grand Am that wouldn't shift. The problem turned out to be the T-handle on the shifter. Most GM shifter handles come off the same way. If there is a rubber/leather boot, pull that down a little to expose a metal clip.
The metal clip can be pulled off straight for\ward (I think), and the handle comes off.
The shifter will be a tube with a plastic rod sticking out of it. Try pushing the rod in, and see if the shifter works. If yes, replace the handle. If not, the problem is probably down in the shifter.
When you step on the brake, there is a cable going from the brake pedal to the shifter. Step on the brake and you should hear something moving in the center console/shifter. If not, the cable could be detached or broken.
The shifter itself may be broken, but that can be tough to get to.
The could be something wrong at the transmission, or inside the trans.
Feb 27, 2011 | 2001 Pontiac Aztek
I have a Campy 10 Speed Shifter, running with SRAM S60 wheels, it causes some problems when upshifting
If you are running a SRAM or Shimano Cassette, then the spacing will be ever so slightly off. If you want to have precise clean shifting then you need to either replace the cassette body with a Campy one and replace the cassette with campy or get a 10-speed conversion cassette such as those from American Classic. Campy spacing on a shimano/ Sram spline.
The wheels in and of themselves should not make any difference.
Another trick for perfect shifting, make sure that your rear derailleur and shifter match - Campy to campy, Sram to Sram as examples.
Jan 02, 2011 | Cycling
I would like to replace the shifter cables on my ultegra flight deck shifters how do i go about this
You will need to purchase new cables obviously, but I would strongly advise that you purchase them as part of a set that includes the outer housing. That way you'll be sure your shifting is smooth and trouble free. You will need to loosen the pinch bolts at both derailleurs and pull the cable loose. Then you can pull them free at the shifter....I'd recommend going to the shimano website or sheldon brown to see illustrations on exactly how to do this. You then replace the cable housings (don't forget to inject some lube into the them) and then rethread the cable. You will also need a cable cutting tool (don't use anything else as the cables will fray) and some cable caps. Tighten the pinch bolt at the derailleurs, adjust the shifting and your done.
May 14, 2010 | Cycling
1997 pontiac sunfire manual transmission won't shift out of gear.
What you can try is to remove the shift cables from the transmission side. then move the shifter and see if everything is free if it's still sticks then the cables are going to be replaced. if everything is moving with the cable off. then you need to remove the shift tower on the tranny (where the shift cable is I belive it's 5 bolts) remove the tower and you will see the shift pin. Inside the tower there is a cotter pin that breaks and that will cause you to have one gear and unable to selected another gear. If you are not mech inclined I would no attemped the shift tower repaire, the cables do it will save you money. The shift tower has bushings that can fall into the tranny.
Jul 02, 2009 | 1997 Pontiac Sunfire
Gear shifter will not go into park
There is a plastic actuator stick under the shift knob. Remove the "horse shoe" clip from the shift knob and remove knob by pulling strait up. You can twist it right and left a very small amount to loosen the knob, but not much.
Once you have the shift knob removed you will see the plastic actuator stick. Push down on the stick and put shift lever in park. If that works, the shift knob or stick is worn out.
Let me know.
Regard,
Feb 12, 2009 | 2004 Pontiac Grand Am
2007 GMC Sierra 2WD 4.3 litre shifter problems (automatic)
More then likely the cable from the shift lock solenoid that unlocks the shifter is binding up or the shift lock solenoid is sticking..
May 04, 2017 | 2007 GMC Sierra Classic
'99 wrangler has trouble shifting to 2nd gear - 4th gear occasionally slips to neutral
If you can see where the shifter goes through the floorboard, make sure the shifter is not hitting the floor.
There could be interfierence under the car also.
Oct 24, 2008 | 1999 Jeep Wrangler
Clark 's Mountain Bicycle Front and Rear Brake Cable Kit, Competition Stainl Logo
139 people viewed this question
Top Clark Cycling Experts
John Egan
John Egan
Are you a Clark Cycling Expert? Answer questions, earn points and help others
