Question about Jenn-Air Ovens
Jenn-air Oven model SVE47500 or SVE47600 will not heat properly-even though the temp setting indicates proper cooking temperature. Also after shutting down a beeping begins that has to be turned off by pressing the cancel button. This goes on for several minutes. Also the fan runs for a long period of time after shutting down. Any ideas what could be the problem? Many Thanks!
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: Jenn Air oven Model D156 won't turn on
get a new range
Posted on Aug 11, 2008
docjohn174
  • 943 Answers
SOURCE: Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
SOURCE: my oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Posted on Sep 17, 2009
Kenmore oven take a long time to heat up, but bakes just fine once it reaches temperature. Is there anything I can do to speed up the heating process?
Start earlier?
>> check all elements for current,
check seals
check temperature calibration (allowed to be 15% ie 180 can be 153 or 207 Celsius!) no wonder Margs' scones cook faster at her house :-)
Oct 15, 2013 | Kenmore Elite Stainless Steel 40" Dual...
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
Our SVE47500 or SVE47600 oven has just completely stopped working. The oven was cooking the turkey throughout the night. The timer started going off and even when you cancelled the timer, it still went...
This sounds like you somehow got a little moisture in the controls. With any luck, after it sits for awhile it will dry out and begin working again. Turn your circuit breaker off and let it sit for about an hour to see if you have any luck. It is possible to speed up the drying process by using a hair dryer aimed at your control panel. Use the cold setting on your hair dryer. Repost back here and let me know how you made out. We can trouble further if your unit still does not work.
Nov 25, 2010 | Jenn-Air Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Time and Temp. display on my JennAir Expressions is not working.
99% likelihood of a bad clock, part # 71001799. This is unfortunately very common with this model. Hope this helps!
Dec 31, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Jenn air single wall oven model jjw8530BAB - exhaust fan not working properly
in not sure but i think that fan runs off a thrmistor that goes to the contol board.open the oven door and look on the right side of the oven see if theres a metal looking bulb.
Aug 19, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
111 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
