Question about Garden
Not getting fuel to the carb on riding lawn mower with 16 1/2 hp ohv. will the fuel solenoid on the carb cause this ?
  • 148 Answers
The solenoid only controls fuel from the carburetor bowl to the main jet.
If you arent getting fuel to the carb bowl your problem may lie upstream of the solenoid.
For "supply issues" check fuel line, inline-filter, shut-off valve (if equipped) and in-tank screen (if equipped).
If bowl is getting adequate supply, the solenoid might be suspect. Remove and clean with carb-cleaner spray as needed.
Hope this helps.
Posted on Oct 05, 2009
Carb float bowl has an electric selanoid on it no wires going to it how does it work and where do wires hook up
Carb solenoid and a fix, dont forget the cut off valve ...
? 10:23
https://www.youtube.com/watch?v=gQw2pQ_oa6o
Jul 16, 2012 - Uploaded by Murray Mayhem
would you advise doing this on a 2004 Bolens with a 15.5 Briggs..... I have a 15 hp Craftsman-koher riding lawn mower that won't run. ... when I put power to it, and the there is gas in the bowlwhen I take it apart. ... Rename the video "How to Bypass Carb solenoid for Temp Fix on no start" Try to edit that ...
Small Engine Repair: How to Check a Solenoid Fuel Shut ...
? 4:40
https://www.youtube.com/watch?v=Kr6UayxyVwU
Jul 23, 2011 - Uploaded by smallengineshop
When the engine is stored with fuel in the carburetor for long periods, there is a .... There is gas in the carb in the lower portion where the float is. .... Engine hadn't been run for over a year and the solenoid would not operate. .... DIY - CarburetorReplacement On Lawn Tractor With Briggs & Stratton Engine ...
Dec 01, 2015 | Briggs & Stratton Garden
Has anyone ever had a problem with the fuel solenoid on the carburetor? Same B & S 20 hp v-twin. If it were malfunctioning could it cause a backfire through the carb?
A bad solenoid on the carb should not cause this. It sounds more like to me the motor is out of time due to a sheered flywheel key. Appears as though the motor is firing while the intake valve is open which is why you are getting a so called backfire through the carb. I hope this has been helpful.
Oct 02, 2013 | Craftsman 42" Briggs Stratton 20 hp Gas...
My craftsman 18.5 HP OHV will not start
first see if the fuel pump is working remove the hose from the carb and crank it over if fuel sprays out it works the see if you have power to the solenoid to the bottom of the carb if so remove the solenoid and put power to the wire and a ground if it is stuck carb cleaner can free it up if it moves remove the bowl from the carb and see if fuel is getting inside the carb a bad needle vale would stop it from getting threw
Aug 18, 2012 | Craftsman 18.5 HP 42"
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower cranks wont start prim carb and runs
check the solenoid on the bottom of the carb they stick and shut fuel off threw the carb
Apr 28, 2012 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I found Gasoline inside My Craftsman riding mower engine, this is the third time I have to drain it and replace it with new oil, somehow gasoline is flowing inside and I have no idea where it is coming...
There is a fuel shut off solenoid on the bottom of the carb and it is most likely stuck open. The gravity flow of the fuel causes it to force through the carb, through the intake valve, through the cylinder and then into the oil sump.
Oct 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where is the sparkle plugs in a yark works riding lawn mower the mower won't start
It should be under a rubber boot between the OHV cover and the muffler.
Drain your carb and check for water in the fuel too.
Good luck and be careful!
Jul 24, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Have troy bilt riding lawn mower engine is not getting gas through carb. what is the solenoid thats attached to the carb?
That is the fuel solenoid that allows gas to get into the carburetor when it starts up. The fuel solenoid opens up when the key is turned on to allow fuel into the main jet of the carburetor.
go to www.precisionope.com, you should be able to find an Illustrated parts list on the engine.
Sep 28, 2009 | Troy Garden
Garden Logo
422 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
