Question about Whirlpool LER5636P Electric Dryer
Dryer shuts off and will not handle a full load. When i go to restart it, i have to wait 15 mins. then it will restart. Sounds like motor is whining at the start of the load, even for light loads. Suggestions?
  • 82 Answers
MOST PROBABLE IS THE MOTOR YOU HAVE TO REPLACE IT!!!
Posted on Oct 05, 2009
Testimonial: "Thank you, i will have that fixed, and have him cut right to the problem."
Need Kenmore 80 series, gas dryer wiring diagram. dryer overheats after 15 to 20 minutes, with a full load of clothes, then shuts off...........wait 20 minutes, then I can restart; ...
you need to send the model number kenmore doesn't make anything,the only way to tell who made it is by the model number but anyway if it stalls on you and you go to restart it does it make like a buzz sound if so you have a bad motor,when the motor cools off it starts again,it's not a t-stat or anything because when they fail they won't work again non resettable,most likely will be the motor
Dec 29, 2017 | Dryers
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 | Dryers
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Dryer starts then immediately stops
sounds as if your motor is overheating nad shutting off.. willl it restart right away??? or will make you wait 20 min before restarting again only for 20 secs??? if so thats a bad motor
Mar 28, 2009 | Amana ALE230RAW Electric Dryer
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
I HAVE A AMANA DRYER MODEL # LE8217W2 THEY DRYER WILL TRY TO START AND TURN OVER LIKE A COUPLE OF TIMES AND WILL HEAT BUT SHUTS RIGHT BACK OFF--BELT IS FINE ELEMENTS HEATS? WHAT WOULD BE NEXT TO CHECK?
sounds as if the motor is overheating, shutting off and not restarting for 10-20 min??? if thats the casse sounds as if yooull need a new motor assemly
Dec 03, 2008 | Amana NDE2330AY Electric Dryer
Dryer shuts down in the middle of the cycle before the timer goes off. if you try to restart it will not. wait 15 minutes or so and it starts right back up and finishes drying the load.
Probably the motor is getting too hot and the thermal overload switch is shutting it down.Usually means bad motor or dirty motor. You'll have to take it apart to see. Model # and Brand would help.
Mar 27, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
74 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
