Question about Panasonic Audio Players & Recorders
Panasonic SC-CH84M stereo. F61 appears regularly & shuts off. Sometimes doesn't go at all. Normally during heavy or loud base tunes starts loud crackng noises and eventually shuts down. Also the light display not always showing but appears when hand pressure applied to top front of unit.
  • 130 Answers
SOURCE: Panasonic SC-PM08 shuts down error F74
Would be cool if that display means you have #74 fuse blown. Maybe its for the amp output to the speakers? have you tried the speakers on another system? could they be blown? Is there anything in the manual about the error?
Posted on Apr 10, 2006
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
tech48
  • 624 Answers
SOURCE: POSSIBLE FAULT CODE
Yes, it is possible. The F61 error is a failure in the power supply or the amplifier. I repair these every day and it will require good soldering and troubleshooting skills to fix this yourself.
If you would like to try, let me know, and I will give you more information. But the best thing to do is take it to a service center and let a professional technician check it out for you.
Posted on Jul 01, 2008
SOURCE: error f61 on a panasonic SK-AK640 CD stereo system
when i turn the power on , it goes off in 3 sec after displaying "f61"
Posted on Mar 01, 2010
  • 75 Answers
SOURCE: on display appears f61
ic stk 470-040 is blown.this is the most common error.just get it changed
Posted on Aug 23, 2010
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
I got panasonic- sa-ak240 stereo system i get F61 on the display then it shuts down to standbye.
F61 is an Error Code......it's basically indicating that something inside the stereo is malfunctioning or broken.
the stereo has gone into Protection mode.....could mean there is Direct Current on one of the output rails....most likely the Power Amplifier IC in your Stereo has gone bad....a new one should solve this problem....you'll need to send it in to Panasonic for replacement of the faulty parts.
Oct 28, 2010 | Panasonic SC-AK240 Shelf System
F61? how do i fix it...................everytime i turn my panasonic sc-ak340 on i get a error code that reads f61 and then my system shuts down by itself..can this be fixed?
I've encountered that kind of problem.
f61 appear on the screen then shuts down the unit.
The very common defect is your fan, output ic (rsn series).
First check the fan if it is in good condition (disassembling the component is quite technical it need a lot of care).
sometimes the fan is full of dirt that's why it will not work properly which the system sense and uttered the unit to switch of avoid further damaged.
If you confirm that the fan is working properly I will suggest you to bring your unit to a qualified technician/service center because replacing the output i.c. is more technical.
Dec 13, 2009 | Panasonic SC-AK340 Shelf System
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
DISPLAY STARTS OK THEN F61 APPEARS THEN STEREO SWITCHES OFF
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Feb 21, 2009 | Panasonic SC-HT441 Theater System
Problems with the panasonic cd stereo system
problems with the panasonic cd stereo system for some days.
The model no is SC- AK640 and i have been experiencing such problems such as "F61" and in the operating guide it says to check and correct the speakers cords i have done that but the problem can not be fix so please if you can assist me that willl be great thank you
Aug 31, 2008 | Panasonic 5 DVD/CD Micro System with MP3,...
POSSIBLE FAULT CODE
Jun 28, 2008 | Panasonic Audio Players & Recorders
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Apr 09, 2008 | Panasonic SC-HT930 System
SHOW ''F61''
This is error code which system control detected either power irrgularities or dc voltage is detected from the speaker out put line.This fault we have noticed that both of them appears same time also.Pls change Amplifier ic TDA8920 and C1740 transistor and 27V1w zener diode.Transistor and zener diode is for voltage regulation and amp ic if the dc detect is active.Usualy change this three components same time.(this all is in power amp section)
Dec 17, 2007 | Panasonic SC-AK340 Shelf System
195 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
