Question about Kenwood KAC-X201T Car Audio Amplifier
Amp will not power up. wired to battery, grounded, rca to stereo. what could be wrong?
    Problem Solver:
  • 5 Answers
Remote wire from cd player needs to be hooked to amp also
Posted on Oct 08, 2009
Instructions for the 500 watt amp
1/remove positive cable from battery.2/install rca jacks to rear of your radio/unit.3/find a suitable safe out of veiw area to mount amp with adequete ventilation [because it will get hot] .4/run and tuck your rca's agian outta site,never in a door jamb.5/also most install kits have a auto on/off wire that runs with the rca wires,that gets tied on to your power antennea wire on the stereos wire harness6/once you have rca,automatic on/off hooked,or near your amp ready to plug in.,you can then , cut as short as possible ,the ground wire[that should be black in color]the shorter the ground wire ,the less feed back you will get! under 14 inches is best .mount the ground very secure under a front seat, loosen a mounting bolt to the seat then wrench tight[making sure it is metal to metal,no paint can be in between contacts then run the power wire [red to red] straight to your battery positive cable [very securely] you should find a access point to push the wire thru the firewall someplace do not hook up the battery though finish runnin the power wire to amps destination after the amp is secure ,add power wire plug ins to amp then runn your speaker wires to box re-attach battery terminals [will be a small spark ] dont panic . upon turning on listen to your favorite song loud,so you can adjust the amplifier to yer liking
Mar 20, 2011 | Visonik Vpb210pk Complete Dual "10" 1,000...
I have an eq tis performance teknique icbn/-5eq 5.1 channel pre-amplifer, i need help to how to connect to the stereo
Your amp needs to be connected to your stereo via rca to the rca jacks in the back of the stereo then connect the remote wire to the remote wire in the back of your stereo it should be blue with a remote flag on it. after that you need to ground the amp and run a wire to the positive terminal on the battery. make sure you install a fuse on the wire in between the battery and the amp.
Jan 29, 2011 | Car Audio & Video
Can you show me a dieagram or wireing up a amp
The process is pretty much straight forward for any amp.
This is what you will need to get the job done:
15 ft- 4 gauge power wire (RED) with in-line fuse 3 ft - 4 Guage Ground wire (Brown) 15 ft - 12-16 Gauge Remote wire (Blue) 15 ft - RCA Wires Here are the steps:
  • BATT - (Battery +12v) - This will be a 4 guage red wire that you will run directly from your car battery to this Terminal. Be sure to buy a wire a with an inline fuse. This is the main power supply to your amp. Be careful 12 volts doesn't sound like much till you see it in action. I would do this wire last, last thing you want is a hot wire accidentally touching some bare metal.
  • GND - (Ground Wire) - This is the terminal you will use to ground the AMP. Run a 4 guage wire from this terminal and fasten it to some bare metal in your trunk. Not more than three feet.
  • RCOM /Remote - There will be a small gauge wire from the back of your stereo that will be the remote wire it will be blue, most stereos have this wire labeled. Its purpose is to send a signal to the amp to turn on when the radio is powered on.
  • RCA Wires - The location for these is not pictured above, on the back of your stereo there will be amp outputs. Your stereo will send all your low frequencies (Bass) to your amp using these wires. On the amp you will see where these wires will go. They are essential to have a system.
The best way to go about this is hook up the power, ground, and remote and test the Amp to see if it powers up. I have seen so many of my friends skip this step and they paid for it later. I hope this helps if you need any more help let me know.
Nov 25, 2010 | Car Audio & Video
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
I got a 4 gauge power wire w a 20 amp fuse hooked up to a kenwood stereo/bridgeable amp 350 watts max power model #kac~6295 it just dnt sound rite any sugestions?
make sure you run your power and ground wires opposite of the rca/speaker wires. you tend to pick up alternator noise when all wires are bunched up together. Also, make sure you have a good chasis ground to the amp, and the stereo has also a good ground. good luck
Sep 04, 2009 | Car Audio & Video
Car stereo pre-out signal noise
Two things, a ground loop isolator in-line with the RCA's between the head unit and the first amp.....also a noise reducing capacitor ( $5 or$6 at an auto parts store) on the alternator 12v post will reduce or remove the hum.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 29, 2009 | Pioneer KEH-P3700 CD Changer
I need help wiring a Scosche SA-500 amp
OK, you run the RCA's from the stereo to the amp. The black is ground and you want this as short as possible. where you mount the amp the ground wire should be no longer then 2 or 3 feet. red is power that you run to the positive post of the battery. you will want to buy a fuse block to this. if there is a power surge this will stop your car from catching on fire(hopefully). lastly should be your constant, this is a blue wire from your radio to your amp. this tell the amp when the radio turns on and off, with out this your amp will stay on and kill the battery. i would recommend buying a amp install kit, their around 35-250 bucks, but they come with every wire you need to install the amp. Hope this helps. you should be able to get a manual on line i would think.
Mar 17, 2009 | Car Audio & Video
Need wiring instructions for vbx12a
You will need the following:
A power wire (preferably 4 or 8 gauge) with an inline fuse (typically 50amps)
A battery terminal adapter to connect the power wire
A signal wire to let the amp know when the stereo is on
RCA audio cables to connect the amplifier to your stereo
A ground wire for the amplifier (again 4 or 8 gauge preferred)
Walmart sells a Scosche kit that has all of the wiring as well as a basic diagram for about $25, but it does not include the battery terminal adapter.
If you have a factory stereo you won't have RCA ouputs, so you will need a line level converter. A basic one like the Scosche SLC4 usually runs in the $20 range. You splice into your speaker wires and run them into the unit, then plug the RCAs into it.
Mar 08, 2009 | Visonik VB-10PKG Car Audio Amplifier
Audiobahn amp help...
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
Feb 09, 2009 | AudioBahn A2002T Car Audio Amplifier
Maystar cx475
Ok, I am assuming this is the 600 watt amplifier?
DISCONNECT YOUR BATTERY!!
Supplies needed:
- 8 Gauge power wire (long enough to run from your battery to the amp placement) WITH an inline fuse!!
- Depending on your stereo (if it has amp pre-outs or not) you will either need RCA cables (long enough to reach your amp from your stereo) OR a Line-Out converter AND RCA cables.
- The power lead that connects to your "REMOTE" line on your stereo (long enough to reach from amp to stereo - usually blue)
- A good ground wire ( long enough to reach a metal part of your car from the amp)
STEP 1: Find a spot to run the power wire from your battery - through your firewall and into your car - and then to your amp. (DO NOT CONNECT IT TO ANYTHING YET)
STEP 2: Remove your car stereo and look to see if you have PRE-AMP outs (RCA connectors for an amp on the rear of the unit)
A- if you do, GREAT.. proceed to step 3
B- if you don't.. you will need to get a LINE-OUT CONVERTER - what this does is converts the higher signals from your standard wires on your radio, to RCA style wires to connect to your amp.
B2- you will also want to buy a wiring harness kit for your stereo, unless you want to hack away at your factory wires.. (not recommended) - connect the harness kit to your factory wire harness, wire in your leads for the output converter, and run the other end to your stereo.*
*you will need to know which wires run to the speakers you plan to power with the amplifier
B3 - once the converter is properly connected - proceed to step 3
STEP 3: Plug the RCA cables into the stereo or converter, and run them properly from behind your radio to the amp but DO NOT CONNECT THEM YET.
STEP 4: Connect the REMOTE wire from your stereo to the same wire for your amp . (this enables the amp to turn on/off with your radio.. otherwise.. you will have alot of dead batteries)
STEP 5: re-install your stereo into the car.
STEP 6: Connect the RCA speakers into the INPUTS on your amp
STEP 7: Connect the REMOTE wire to your amp.
STEP 8: Connect the speaker wire from the OUTPUTS on your amp to the speakers you wish to power
STEP 9: Connect the POWER CABLE to the amp PROPERLY
STEP 10: Connect the GROUND CABLE to a metal part of your car (sheet metal, not just a bolt)
STEP 11: Connect the POWER CABLE to the battery cable
STEP 12: Re-connect your Battery
STEP 13: Start your car, and test your radio.
If you have any issues from here.. you need to re-check all of your connections.
Oct 12, 2008 | Car Audio & Video
Kenwood KAC-X201T Car Audio Amplifier Logo
123 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
