Question about Samsung WF337AA Front Load Washer
SOURCE: Samsung WF317 Front Load Washer code nd
Check the drain pump itself. But at the same time if your clothes are still sudsy it sounds like it is not going through all the cycles. Almost like it is skipping a cycle
Posted on Feb 12, 2009
SOURCE: Samsung front loading washing machine won't spin out.
We had the same problem. We ordered the washer on Black Friday and just got it this past Sunday. We put laundry in and it would not spin. We got the dc code. We have been on the phone with Sears for the week. A repairman came out to look at the washer today. He couldn't find anything wrong and had to call the tech people for help. They said if the washer is in a space that is below 60 degrees it won't spin because the oil in the back of the drum is too thick when it is cold. They have to order a new board to heat the oil. We thought they were crazy. So we did our own experiment and put a heater in the basement. The washer worked! Now we are just waiting for the new board to see if that solves the problem so we don't have to heat the basement just to wash clothes. I am glad we can at least heat the basement and wash clothes until the part comes. I will post after it has a new board!
Posted on Feb 22, 2009
SOURCE: front loader wont spin
Hello there:
It doesn't spin
If your washer won't spin, check these:
If the motor is running, the lid switch may be
defective. If so, the washing machine can't spin and may not function at
all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the
washing machine to get to the switch. If it's defective, you need to
replace it
The motor coupler may be broken. Many
Whirlpool®-manufactured washers use a small, relatively inexpensive
motor coupling. It's plastic and rubber and is mounted to the shaft of
the motor on one side, and to the transmission on the other. Over time,
the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one
or two belts. If a belt is broken or badly worn, you need to replace it
with a genuine belt from the manufacturer. (Some washing machine belts
are designed with special characteristics not found in automotive
belts.)
The clutch may be worn. If your washer is a GE, it may
use a clutch to come up to the proper spin speed. As the clutch wears
out, it may prevent the unit from spinning well or at all. If the clutch
is worn, you need to replace it. For this job, you probably want to
hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands
use a reversing motor. For agitation the motor runs in one direction,
for spinning and draining, the other. It's possible for a motor to burn
out in one direction and continue to operate in the other. If this
happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older
washers produced by Whirlpool® have a transmission with an
electro-mechanical shifter. If the shifter becomes even partially
defective, the unit may drain the water but not spin. This is a complex
system, if your washer has a shifter problem, you may want to hire a
qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or
seized. These components allow the inner tub to spin freely inside the
outer tub. When this is the problem, you usually hear a loud sound
during the spin cycle.
Posted on May 15, 2010
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
Posted on Aug 16, 2010
May 08, 2017 | Kenmore Washing Machines
Oct 16, 2016 | Samsung Washing Machines
Mar 06, 2014 | Samsung WF203ANW Front Load Washer
Mar 11, 2012 | LG Washing Machines
Mar 03, 2010 | Samsung B1245 Front Load Washer
Jun 19, 2008 | Samsung Washing Machines
Feb 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Jul 19, 2015 | Samsung WF337AA Front Load Washer
