Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Power button will not stay on. keeps going back to blinking orange. is it time for a new one...dell dimension 5150 pc
  • 3,940 Answers
Blinking orange Power LED is an indication of a failed power supply in the tower
Posted on Oct 04, 2009
Orange flashing light on a dell dimenson 5150 computer won't start up
The orange flashing light on the power button is an indication of power supply failure.
Your Power supply unit needs to be replaced.
Aug 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
My Dimension 5150 box will not turn on! Just blinks, looks like an orange light. Monitor comes on then goes off to orange...
- disconnect the power cable of the box from the back of the tower and press and hold down the power button for 10 seconds (remaining power will be depleted).
- Now try using a different wall outlet.
- Check the diagnostic lights to see if the specific problem is identified (the computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel). Also, see "Power Problems" in your computer Owner's Manual and/or Service Manual.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1120147
Nov 03, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 does not start
Could be a number of things, First take the ram out and then put it back in and see if that helps. next I would unplug any devices not required to start the computer.
You need to be familiar with the inside of the computer to do this.
Most likely suspect however is the power supply.
Jun 19, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150c
The flashing orange light is an error code. Dell tech support can tell you exactly what the code means. Hope this helps.
Jan 25, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 PC
this sounds like a motherboard fault, the green light shows power to the board but the orange can indicate that the board has failed
Sep 15, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Orange Light
you need to replace the motherboard lithium battery. Looks like a watch battery.
Sep 07, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Wont turn on
I know this is an old post but for the sake of letting others know, I also had this problem with my Dimension 5150 power on button blinking amber and not responding, this was after only buying the machine in April 2006. I first took the base unit to PC World who told me the machine was knackered and i should invest in a new one, unhappy with that answer I contacted Dell who run through this whole process of pull this out, plug this in, power up, press the cd drive button etc.. etc.. all of this narrowed the fault down to a "faulty input/output panel" according to Dell, however i did some more testing of my own and found a small round flat silver battery on the circuit board, i simply popped this battery out gave it a clean popped it back in and my PC fired up first time and is now performing better than it ever has done. The only effect I can tell is that the computer date and time settings reverted to March 2006, which is easily corrected!
Oct 18, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
315 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
