Question about Pentax Optio M20 Digital Camera
Battery shows empty with new batteries. Recent development. Put batteries in, take a couple shots, battery is empty. Tried with several pairs of batteries. Contacts OK and tight. Suspect a software issue.
  • Customer Service
    Customer Service Nov 29, 2016
    Without knowing more, I'd say try rechargeables (NiCd batteries work well for a test like this). They can deliver more current without dropping voltage.
    If you are using alkaline batteries they will drop voltage at high currents, the kind of current that many digital cameras draw, and the camera will report low or empty battery.
  • Pentax Expert
  • 362 Answers
Take a look in your camera's menus. There should be a place where you can select rechargeable or non-rechargeable batteries. That setting enables or disables the battery charging circuit. If you are using rechargeable batteries, the camera must be set accordingly so that the battery charger will turn on. If you are using
Alkaline batteries such as Duracell or other types of non-rechargeable batteries the charger must be disabled. If you do not set that parameter correctly, you will get the symptoms you describe.
  • 107 Answers
SOURCE: S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Posted on Mar 23, 2007
  • 346 Answers
SOURCE: New batteries but no power...
Have you tried cleaning the battery terminals with a bit of alcohol on a Q-tip? Make sure the terminals are completely dry before inserting new batteries. I am not sure if this is your problem as it may be a lose connection between the battery unit and the camera. Best of luck.
Posted on Aug 06, 2009
  • 2761 Answers
SOURCE: "Batteries Depleted"
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 02, 2009
Testimonial: "SORTED,THANKS"
  • 11967 Answers
SOURCE: batteries don't work
Clean the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Posted on Dec 03, 2009
SOURCE: Pentax K100 Super D clicks, but no pictures.
Hate to say it, but it's dead. My Pentax K100 D Super did the same thing. Took it to the local camera shop. They scratched their heads and sent the body to Pentax. The reply that came back was that the circuit board was completely fried and it would cost more to fix than it would to buy a new body.
I was out of luck because the warranty was out (had it a year and a half), but with yours being less than a year, you should be able to get a new body without having to shell out $$$.
Posted on Jan 02, 2010
Battery not charge
the battery may have developed a memory from continually recharging a partially used battery. The battery charges to this point and reads fully charged but when used it shows as flat because the charged portion is the bit that is used and not the whole battery. Replace the battery with a new one and only charge the battery when it shows as flat.
Sep 15, 2013 | Sony Cyber-Shot DSC-F717 Digital Camera
Battery level quickly empty
I recommend you to buy a new battery. If this doesn't work. Just buy a new Camera, because the engine probably broke.
Dec 28, 2011 | Olympus SP-570UZ Digital Camera
My sony cyber shot turns off after it says for use for compatible
Seems battery got bad and camera does not recognize it.
Take out battery, put it on charger and charge it, put back battery in camera and check.
If problem still exist, use new battery.
Aug 29, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
My battery lasts for about a dozen snaps only
what battery type and size/capacity are you using?
Jun 29, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
Phone regularly cutting out
This is due to malfunction of battery,
i have also experienced same kind of problem with nokia set which is other model. i have also done same what you have done. Change or replace your mobile battery. so it 'll finally solves your problem.
Apr 21, 2008 | Nokia 2310 Cellular Phone
Digicam problem
Is it rechargable batteries (orignal for the camera), or are you using standard batteries? (AA/RC6 kind of batteries)
If you use AA batteries (or similar) make sure you use alkaline batteries of a good brand. Cheap batteries ofteh don't have the power to run digital cameras. Especially using the LCD screen drains the batteries.
If you have a new rechargable battery and it last only a short time see if using it and recharging it a few times helps the bettery "getting into it". If not, your camera may need repairs.
Mar 13, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Battery problems
Check the battery contacts inside the camera. Use a strong light, and if you see corrosion (black or greenish areas) on the contacts, rub them lightly with a pencil eraser until they are shiny.
Apr 05, 2007 | Canon EOS-1V with 28-105 and 100-300 lens...
Low battery indication
You have either a faulty charger, a faulty battery or a fault in your camera. I purchased 2 batteries for my Sony 505v and from new one of them kept flashing an empty battery sign right in the middle of the display. Actually it was fully charged but Sony batteries have a little circuit inside them which tell you how long the batteries will last. In my case I could continue to use the battery but put up with that flashing icon. I returned it to where I purchased it and it was replaced Immediately. Please ,next time give us a little more information as to what battery type it is and which camera it goes in. Some cameras can develop a natural short circuit over time. BMW
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Dead Batteries
AA's only last for 30-40 shots and should only be used as a very last option.
Sep 14, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Pentax Optio M20 Digital Camera Logo
87 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
