Question about Craftsman Garden
My lawn mower just quit running it is two years .Ino it is a fuel problem but what /
  • 389 Answers
If you KNOW FOR A FACT that it is a fuel problem you might try removing and cleaning the carburetor float bowl and the main jet in the carburetor.
I can't offer much advice when you don't specify what engine it has or what is the model number of the mower.
There are as many or more different combinations in lawnmowers as there are in cars thus we need to know more information when you ask for assistance or we just have to guess!
Posted on Oct 05, 2009
This mower just quit while running , now will not start
If spark and fuel flow are both good then the problem might lie with the carburetor needing to be cleaned out.
May 10, 2015 | Garden
Why did my lawnboy lawn mower quit while it was running?
If your not out of gas then loosen the fuel cap a bit and start your engine. if the unit keeps running then replace your fuel cap because it's not venting which builds up pressure in the tank and stops fuel flow. Another possibility is that you got dirt in your carb and it's blocking a passage. In this case clean your carb
Jul 16, 2014 | Garden
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
Husqvarna YTH1842 stops running when hot
Try slackening the fuel filer cap, if the breather is blocked in the cap it will vacume and stop the fuel from flowing, if it runs ok with the cap loose replace the cap.
May 18, 2013 | Husqvarna Garden
I have a 16 year-old MTD lawn tracotr with a 12.5 hp briggs & strattion engine. The tractor will run for 5 minuted then quit. It appears that the n(new) fuel filter is not full, thus gas is not...
Were the engine rpm's steady when it died? If it was hunting, the carb. probably needs cleaned.
The fuel filter can maintain an air bubble in it and still flow plenty of fuel. So does it restart after it dies? You can check the cap by running with the cap a little looser and see if it dies, I have not ever encountered a cap failure, but you could look to see if the vent hole in the cap is plugged.
If you had a crack in the fuel line or were sucking air in somewhere it probably would not run right from the outset.
Aug 12, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Mower only runs two min and quits
Sounds like a blocked or dirty fuel inlet.
Remove the carb bowl and work the float up and down until gas flow improves. Be gentle! Just a little light pressure from beneath and the float should swing up about a quarter inch.
The short run is due to the carb bowl not refilling fast enough to keep up with full throttle demand.
Make sure when you put the carb bowl back on there arent any fuel leaks before trying to run the mower.
Good luck and be careful!
Jul 25, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Riding lawn mower won't start
The carburetor is clogged from old fuel. remove and clean and consider getting a carb kit to give it new seals and gaskets and needle/seat. Sta-bil in the fuel, particularly over winter will prevent this problem. When the work is done, be sure to drain the old fuel and use fresh.
Jun 25, 2009 | Garden
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
146 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
