Question about Pentair Pool & Spa
Pential Easy Touch Pool/Spa remote says the water temp is 225 degrees F. The Spa will not be allowed to heat up because the system is thinking the water temp is 225 degrees. Seems to be a sensor issue. Took the panel apart and checked the wires going into the water sensor circuit. Everything looked fine. No luck
    Problem Solver:
  • 5 Answers
You can change the calibration on the temp. or how did you check the sensor
Posted on Oct 05, 2009
Our heater will not heat past 78 degrees. How do we get it to heat above that. Is there a factory set temp control problem? Thank you
Yes there is, but only a service technician is allowed to adjust it. However, the fact that you are only reaching 78 degrees makes me think something else is wrong.
Your bypass valve is probably the culprit. It is located where the Pipes enter the heater. It has a spring on it that is thermally activated to open and close. This allows the right amount of water to pass through the heater. Too much water and the water will not heat up. Too little water and the heater will vibrate and howl!
You could also have a faulty thermostat.
Also, always use a heater blanket when trying to heat a spa or pool. It will save you lots of money and time! And they are cheap!
Apr 16, 2011 | Pentair Minimax NT Heater
My heater is heating to 100 degrees as indicated on the heater, but the actual temp in the spa is much less, usually 10- 15 degrees less
Press menu, scroll to settings. There should be a choice labeled "calibrate". You can change the temp reading here.
Mar 27, 2011 | Pentair Easy Touch Indoor Control Panel...
Have pentair easy touch controls just installed new water temp sensor. spa is 88 degrees but master temp heater shuts off because it reads 104. what should i check? the thermistor/
If the Easy Touch is reading the correct temperature, but the heater is not - you need to double check the temperature of the pool water with a standard pool thermometer.
Other things to consider:
1) The water is traveling too slowly through the heater. If the water is heating too quickly, then it will shut it off. If it takes a while for this to occur, then this would not be the issue.
2) Thermostat/thermistor is incorrectly reading the temperature of the water prematurely shutting the system down.
Make sure you really are checking the temperature of the water and matching this temperature up with one of the two readings that you are getting. Don't just take the word of the displays on either unit.
Dec 10, 2010 | Pentair Mastertemp Heater
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Heater reads spa water 15 degrees higher than it is
if a 3 wire system put pool at temp desired and spa at 104 if 2 wire to firemans switch run heater all the way up to 104 the system will control the temp
Feb 22, 2010 | Jandy AquaLink RS2/6 All Button Dual...
Turned the temp for the spa up to 100 but it heated the pool too!?!
If you have automatic valves that switch over to run the spa, make sure that the valves turn completely to where they are supposed to be. Normally it will be about 180 degrees from where they are when in pool mode. If you have to change the valves over manually, make sure they're in the proper position. The only time this can happen is if the valves are not in the right position allowing the heated water to return to the pool. The thermostat on the heater will heat the water to the prescribed temperature no matter how you have the valves set. So if you place it on spa mode, it will heat whichever body of water that is flowing through it to that temp. If you have an automation system, double check the valves. That is probably where your problem lies.
Oct 05, 2009 | Hayward H Series Pool & Spa Heater 400k...
Water Temprature read 126 on heater and will not fire. Pool temp @ 72 degrees. Heater set for spa @ 101 degrees. SR400NA Sta-Rite Heater
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Oct 04, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pool & Spa Logo
494 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
