Question about Dryers
Dryer just dose not start I know there is power at the machine
  • 82 Answers
THE MOST COMMUN THING IS THE SWITCH'S DOOR CHECK IT AND REPLACE IT IF NECESSARY!!!
Posted on Oct 05, 2009
What dose PF mean
I would check the power to make sure of the polarity, two hots and a ground. Once that checks out ok and still has a problem, check the power cord connections in the dryer, that green wire goes to chasis ground or terminal N, G, and the solid color wires to the line 1 and line 2. If it still trips on PF, then a wiring diagram and tracing the power failure is needed, perhaps a control transformer but its too early to say now. Diagnose.
Feb 04, 2015 | Dryers
Machine Stopped working. lights come on but grinder doesn't start
Suggestion:
Make sure there is no capsule trapped in the machine.
Unplug the unit and with for about a minute.
Plug it in again.
Same problem again: repeat process, but reset the dosing (see the manual - I believe it is done by holding buttons down on start-up, or something similar)
You may have simply put the machine in a kind of learning mode, in order to alter the dosing setting which has a default.
Apr 14, 2014 | Nespresso Essenza C100 Espresso...
WON'T GO ON
There would seem to be a problem with your control board bypassing control selections............service technician required for repairs to this problem.
Nov 12, 2013 | Frigidaire Electric Dryer
My dryer power light comes on but it dose not spin the power light is low ? what do think is the problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2011 | Dryers
We had an older dryer, and it got to the point that it would run a couple minutes, then quit. We bought a brand new Kenmore Elite dryer... model 110.64994300... and it does the same thing. We thought it...
if you have a volt meter u can check power coming in should b 220 volt put one meter leave on black wire an the other on red wire meter should read 220 volt an if u go front black to white it should read 110 votl u could have a bad outlet dose outlet look like it been burn if best if you dont know how read meter to just call your appliance repair service ok be safe an turn power off to dry b4 you start test it out ok hope this help you out
Jun 02, 2017 | Kenmore 64992 Electric Dryer
Crosley dryer Cdes563sq0 if i turn the timer on befor i push the start button the heat will start but the moter dose not start.even after the button is pushed.
It sounds like there is a problem with the motor/belt. If you can get the top up, mine you have to push in two clips between the lid and the body about two inches in from the right and left sides, you can look down into the machine to see if the belt is still on track or if the motor is turning. I had one dryer that the belt would come off the spring tensioned idler pulley. Best of luck
Mar 21, 2010 | Crosley CDE6000 Electric Dryer
Washing machine dose not aditate anymore
pull up the agitator, you may need to get a belt wrap it underneath and yank it up, please be careful that it doesnt hit your eye and under the agitator is a coupler or bell that needs to be replaced, it is stripped, loosen the bolt and replace
Mar 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
The washer/dryer combo dose not stop filling up with water
check the fill valve and the connections to it the problem probly lies inthere. the valve is located inside the machine where you water hooks up.
Jul 09, 2009 | Washing Machines
Ink in Dryer Drum,how do I get it out
this dryer still under manufacture warranty, but here’s my the problem, week ago we had a basement fledging and right after that the dryer won’t start, under this situation dose machine will be cover or no.
Sep 19, 2008 | Dryers
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
