Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printer is catching on the bottom right section of paper when printing
When I print several sheets of text/images, most of the pages are getting roughed up on the right bottom edge of the paper as the inkhead passes over the last part of the paper for the last few inkhead passes over the paper. it's rarely used and have had it less than a year.
    Problem Solver:
  • 12 Answers
When was the last time you changed the cartridge/inkhead could be ink buildup and causing it to snag Inkjets are horrible about drying and clogging. if inkhead is removeable you may take it off and clean the area that comes in contact or proximity to the paper, I would also check the bottom part of the roller and housing for anything that could be jammed in there or stuck.
Posted on Dec 22, 2007
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The printer will not print from Microsoft documents. Paper feeds but no image/text. New cartridges have been inserted.
Go to Printers and Faxes
When the page opens you should see an icon with the make and model of your printer there.
There should be a tick against it saying it is the default printer if not right click on the icon and select "make default"
If the tick is there hit the "print test page" box at the bottom of the page , the printer should do a single test sheet
If not make sure you have your installation disk handy for the printer then go to Control Panel select Remove Hardware and delete the printer
Re-install the printer from scratch again
Jun 08, 2009 | Dell 924 All-in-One InkJet Printer
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 19, 2009 | Dell Office Equipment & Supplies
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Laser Jet 4 Plus
Make sure your sheets are aligned and tucked in with the paper feed rails, otherwise, it will slightly veer off one of the sides.
Also, if you haven't replaced the paper feeder rollers, do so, one must be worn out more than the other, and this also prevents the sheets from going through straight.
Hope That Helps!
Feb 01, 2008 | HP LaserJet 4 plus Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
48 people viewed this question
old marine
old marine
