Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
  • 148 Answers
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Posted on Oct 05, 2009
How do i replace a accelorater cable on a 1997 blaser
Disconnect cable at throttle butterfly undo the retainer bolt on firewall and pedal leaver slide old cable and new one in the same position.
Nov 08, 2014 | 1997 Chevrolet Blazer
Tip
Throttle Position Sensors on engines
1.3) TPS - Throttle Position Sensor
What is it? This is an electrical device that detects the position of the throttle plate.
Where is it located? The TPS is found on the exterior of the throttle body on the opposite end of the throttle shaft to the accelerator linkage arm. It usually consists of a small black plastic unit with an electrical connector attached to it.
How does it work? The TPS is a variable resistor madeup of an arc shaped carbon track with an applied voltage of 0 to 5 volts along its length and a sliding contact that picks up the voltage at any point along it. The device has three electrical connections, two provide the voltage range along the carbon track and the third (most often the middle connection) sends a voltage to the ECU in accord with the position of the sliding contact point on the arc. This siding contact arm is attached to the end of the throttle shaft. As the throttleshaft rotates, opening and closing the throttle plate, the sliding contact sweeps up and down the carbon track providing voltage readings to the ECU; 0 volts for closed to 5 volts for fully open.
When the engine is at idle the TPS output should signal the ECU that the throttle is closed (low volts) and therefore the ECU should either open the Idle Air Control (IAC) valve or (on some engines) engage the idle speed control motor to maintain the engine idle speed. Sometimes a micro contact switch on the throttle body exterior associated with the throttle shaft is used to detect and confirm when the throttle plate is fully closed.
NEXT 1.3b) TPS faults and how to fix
on Jul 15, 2011 | Mercedes-Benz E-Class Cars & Trucks
2000 gmc serria wont stay running unless you feather the gas pedal after a minute or so it will be fine after it warms up it runs great
you have a bad idle air control valve and also a thottle position sensor. both sensors are located on the throttle body
Nov 25, 2012 | 2000 GMC Sierra
What is engine code p1120 dtc
DTC P1120 - Boost Pressure / Throttle Position Sensor Malfunction
Hope this helps. God Bless
Apr 07, 2011 | Dodge Durango Cars & Trucks
I HAVE LEXUS RX 300 CHECK ENGINE LIGHT ON AND BY USING MY OBD.II IT GIVES ME THESE CODES PO120 AND P1400 SO I WANTS TO KNOW EXACTELY WHAT IS WRONG THANKS
P1400 Sub-Thottle Position Sensor Malfunction
PO120 Throttle position Sensor Malfunction
Sound like the throttle position sensor is acting up, you might have to flash the computor when installing a new sensor. check.
Jan 31, 2011 | Lexus RX 300 Cars & Trucks
Transmissions won't stay in overdrive
Its the throttle positioning sensor,Its located on the throttle linkage on the thottle body.
Dec 31, 2010 | 1993 Chevrolet C/K 3500
Ak38001 admiral washer need to replace drive belt
To change the drive belt you must unplug the washer and lay it forward on its front. Put some cardboard down so not to scratch the paint. Remove the two screws holding the rear panel and remove panel. Undo two bolts holding the pump on. There are three bolts holding the transmission into the washer. Locate the one bolt which has a spacer between the transmission and the post under the transmission. Remove the silver spring at the corner of the transmission. Remove the belt from the large silver pulley.
You will notice the part with the two coils called the wig wag. Under the left coil is a flat shaft. Rotate the large pulley to advance the flat shaft till its as far forward as possible. Insert a large screwdriver into the slot of the flat shaft until it comes out of the vertical shaft that it is inserted into by rotating the pulley with the screwdriver inserted into the slot in the shaft. Drop the vertical shaft till it almost comes out of the slot of the transmission it is inserted into. Tap the gray yoke off the top of the vertical shaft to allow enough room to slide the belt out. Slide the belt from where you removed the transmission bolt and spacer. You should now be able to remove the belt.
Slide the new belt through the space where the bolt and spacer was removed.
Slide the belt through where the vertical shaft was lowered.
Position the belt around all pulleys except the pump pulley.
Reinstall the transmission spacer and bolt.
Reinstall the flat shaft through the vertical round shaft by lining the flat shaft with the slot in the vertical shaft and rotating the large silver pulley until the flat shaft goes all the way through the vertical shaft.
Tap the yoke back into the top of the vertical shaft with the white plastic clip.
Reinstall the spring.
Line the pump pulley behind the belt and make sure the pump activator is positioned into the groove of the flat shaft controlled by the wig wag.
insert the two pump bolts.
You should be ready to go.
Jan 03, 2010 | Admiral Washing Machines
Replace the tray 2 pickup roller assembly
The tray two pickup roller is a roller in the front of the tray. Remove tray 2 and place it on a level work surface. Locate and open the cover that is
next to the roller in tray 2.
Pinch the blue latch that is on the left side of the roller. Slide the roller off of the shaft.
Then you can slide the new roller back in.
CAUTION When you install this roller, make sure that it locks into place. Verify that the
roller is correctly oriented, and that the round, black spacer next to the roller is correctly
positioned against the locking pin on the shaft.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | HP LaserJet 2430n Printer
Rear axle berrings
Tools needed- typical socket and ratchet set, Axle slide hammer, Wiz Wheel type rotary cut off tool, chisel, ball pein hammer, hydraulic press, bech vice
First you must remove the rear wheels, then you must remove the brake capiler and mounting bracket, remove the brake rotor. unbolt 4 nuts on back side of brake dust shield that hold the seal and bearing securly in place. then you must attatch the slide hammer to the axle shaft by using the vehicles lug studs and lug nuts. use the slide hammer to knock the axle shaft out of the housing. it generally takes about 10-15 hard slams before it comes loose. once axle shaft is free to come out remove the slide hammer and pull the shaft from the axle tube. place the axle shaft into a vise and use the cut off wheel to cut off the bearing spacer. cut parralell to shaft until you hear a snap sound once it snaps use the hammer to slide the spacer off the end of the shaft. next you need to cut the bearing off the shaft using a the same technique being careful not the cut the shaft or the seal retainer plate. once the bearing is off then you can slide off the old axle seal. now slide on a new axle seal, axle bearing, and bearing spacer. take assembly to a hydraulic press and press the spacer and bearing onto the shaft until it seats squarely and make sure its all the way down onto the axle shaft. lubricate bearing with gear oil. and install shaft back into axle tube making sure that the recess in the seal retainer plate lines up with the abs sensor wire. tighten all nuts evenly top off gear oil
Dec 27, 2008 | 1999 Jeep Grand Cherokee
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
467 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
