Question about Pioneer DEH-P7900BT CD Player
Private Phone Calls
I need at times to make a call become private. I don't know and can't find how to temp disable BT so I can talk on the phone (with others in the car being left out of the converstion) and then rejoin everyone again.
    Scholar:
  • 98 Answers
Doesent it have a mute button or a att button?
Posted on Jan 06, 2008
All incoming calls say Private
Hi Helen,
Try disabling caller display. Prove that you have managed it and then enable it
Aug 03, 2015 | Uniden DECT 6.0 Cordless Telephone...
Tip
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
1. MOVE HELP FILES TO MEMORY CARD
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
Enable CAPS OFF
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
2. DISABLE LIFEBLOG PERMANENTLY
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db
C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db
C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\101F99FD\nsmladapterlog???.dat
C:\private\101f9a06\nsmldmtree.db
C:\private\100056cf\clockapp.dat
C:\private\100059a8\nitz.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
C:\private\100012A5\101f8683_ScShortcutEngine.db
C:\private\1000850\logo*.*
C:\private\100012a5\DBS_10205030_accpolicydb.db
C:\private\1000c959\localdata\commondata.D???
C:\private\1000c959\localdata\localdata.D???
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
How to block calls on home phone that show up as private caller
You would have to subscribe to that feature from your local phone company, then when a number like that calls they will get a recording that states you do not accept blocked calls...
Jun 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How to block private call to my cellphone
you wouldnt be able to block private calls .... sorry!!!!
Dec 21, 2013 | Uniden TRU8866 Cordless Phone
People keep calling me on a private call and i need to know there nuber to call them back how do i go about doing that
Usually private calls made are from a phone card so basically you cannot return the call. Hope this helps
Oct 21, 2009 | Cell Phones
All Incoming Calls Show As Private Number
First thing : the person who's calling you have CLIR . Don't put the same number to phone & SIM. Use the phone memory and also save numbers in international format.
Jul 12, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Why does every number that calls me come up private?
try turning off yioru phone and take battery out for about a minute. if that done work, try resetting your phone setings to default settings. if neither works you will have to get a hold of your phone service provider because it may be a problem with the phone or programming itself
Apr 23, 2009 | Cell Phones
Block private calls
this will solve your problem
http://www.trapcall.com/features
or find out who is behind the calls with this feature
Apr 21, 2008 | RIM BlackBerry Pearl 8100
Pioneer DEH-P7900BT CD Player Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
