Question about Refrigerators
Whirlpool side by side, ice flap will not close properly on its own and when manually seated, does not stay in place. Tighten something, replace something, is there a motor or device that controls this or some mechanism connected to the dispenser
    President:
  • 1,304 Answers
You need to replace the soloinoid
it hangs because of rust bild up
it does not drop into the reciever there by hanging the door
Posted on Oct 06, 2009
I have a whirlpool refrig model # ED5VHEVB06. The door where the ice comes out has a flap that does not close completely and a small black plug dropped onto the floor. Now the ice gets jammed and do
sorry , but to properly fix the problem you need to disassemble the door frame from the inside panel, if you are capable you may do but better to have trained technician to do it
Mar 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube door between freezer and outside is not closing. Appears loose or disengaged from closing mechanism.
Generally, ice cubes sometimes get stuck on the flexable cover and will not close properly if they get stuck between the flap and the chute. A hair dryer blasting on the flap will dislodge them and let the mechanism close properly
Jan 10, 2011 | Whirlpool ED5HHEXT Side by Side...
Ice maker making ice but only gives out crushed ice
I had this problem and found it was caused by the flap in the ice dipenser staying open. When I manually closed the flap it corrected it. Now I have to find out how to change the flap.
Jun 13, 2010 | LG LSC27931S Side by Side Refrigerator
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Ice machine flap doesn't close all the way,then stays closed
There is a ice door solenoid for your dispenser, its probably the problem. Costs about 35 dollars and just about anyone can replace it.
May 29, 2009 | GE GSS25JFM Side by Side Refrigerator
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
