Question about Fuji FinePix S1 Pro Digital Camera
Keep getting FEE error on top LCD screen - not sure how to get rid of it. It won't allow me to take any pictures.
    Problem Solver:
  • 18 Answers
Generally it means that the camera cannot communicate w/ the lens. Make sure that the lens (assuming you are using a lens w/ a manual f/stop ring) is stopped down to it's highest #. often it's a different color than the other #s. If that doesn't work, take off the lens & clean the contacts on the lens & body w/ a dry cloth.
Posted on Oct 05, 2009
How do I get rid of the errors on the top of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Televison & Video
I have a two wide line at the top and bottom of my tv picture. how do i get rid of lt? modle number dp37647-e-mail louisdyersr@yahoo.com
Sounds like you just need to change your display mode, look on the remote for a button that says zoom, also in your display menu with your remote, there also should be a setting that allows you to switch from standard widescreen etc. choose full screed or wide screen mode that should get you back to full screen, please keep me posted I would be glad to Trouble shoot this issue until resolved.
Jun 11, 2011 | Sanyo DP37647 37 in. LCD TV
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
May 05, 2010 | Belinea 10 15 36 15" LCD Monitor
I got and fEE... and figuered out it means error!!
This might be a long shot, but on the lens section of the guide shown below, it notes ,,,,
Non-G lenses will have an aperture ring on the base of the lens where it's attached to the camera. Set this this ring to the smallest aperture (largest number), usually in orange and 16, 22 or 32. There usually is a lock to keep this ring set there, since if it comes off that setting you'll get an error message (fEE) from most cameras.
Full guide is here:
http://www.kenrockwell.com/nikon/d90/users-guide/index.htm
Hope this helps
Mar 06, 2010 | Nikon N60 35mm SLR Camera
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
I can't get a full screen picture black band across top and botto
try adjusting the aspect ratio. on widescreen movies or shows you will still get the black bands on the top and bottom. if you play with the aspect ratio you can sometimes get rid of it
Apr 19, 2009 | Protron PLTV3250 32 in. LCD Television
Error Code FE E
Make sure the F-stop ring on the lens is turned to the minimum aperture setting. Usually 22 or 32. The camera won't allow you to shoot unless it is. It will try to warn you by flashing the FEE code.
CameraRepairs
Aug 03, 2008 | Nikon N75 35mm SLR Camera
Black LCD screen everytime i turn my camera on
I've had the same problem for a while now too.
The camera has been useless and Im looking to replace it.
Im sure this problem hasnt got a simple fix and im better off buying a new camera!
Id like to here if someone managed to get it fixed thou ?
Thanks
May 03, 2008 | Kodak EasyShare C533 Digital Camera
FEE error message
To get rid of the pesky fEE just set your lens to f22 or f16 ( depending on what lens you have ) and that is all. You might also want to lock this setting in ( if it is a Nikon lens then the lock is on the side just above the lens aperture ring.
Dec 07, 2007 | Nikon N55 35mm SLR Camera
Fuji FinePix S1 Pro Digital Camera Logo
172 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
