When the outside temperature is below 60 degrees my Bosch Boombox will not turn on. Once I take it indoors where the temperature is above 60 degrees, after a few minutes it will turn on and work fine for the rest of the day.
everything is working with the radio except the redio itself any suggestions what might be wrong...
(More)
everything is working with the radio except the redio itself any suggestions what might be wrong with it
My PB10-CD power Box was overloaded due to bad ground connection in garage breaker box. The GFCI...
(More)
My PB10-CD power Box was overloaded due to bad ground connection in garage breaker box. The GFCI does not indicate or test or reset. There is no voltage output from the GFCI. Can it be bypassed to allow normal operation of the Power Box without GFCI protection?
