Question about Toastmaster TBR15 Bread Maker
The kneader doesn't rotate anymore - Toastmaster TBR15 Bread Maker
  • 50 Answers
A broken drive belt is probably the cause though the electronic board may have a fault.
Posted on Oct 05, 2009
Bread kneader gets stuck in loaf
That is going to happen often with breadmachines, especially when making breads with thick crust. The only way to avoid it 100% of the time is to make dough with your machine and then do the final rising and baking in the oven. There is one other thing you can do to avoid the dreaded" paddle injury" to your loaves and still bake in your machine. Visit me at breadmachineshelp.com and I'll reveal my little trick!
Feb 06, 2013 | Kenwood Bread Machine BM350
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Folding button detach
Hi Frank - Glad to hear that you've managed to rectify that issue!
Nov 27, 2011 | Quinny Baby Gear
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
I can't get the kneader blade out to clean it. I need to use it immediately! in order to exchange it if it doesn't work. Does it just pull up like the others? I have had several other machines...
Yes it should just pull out. Cover the paddle with warm soapy water for about 1/2 hour and push up and down on it. It should pop off after a little jiggling. If not email me.
Sep 09, 2011 | Toastmaster 1183N Bread Maker
The dougn kneader does not work. can hear the "ka
Your drive belt has probably either broken or come off. Make sure your machine is unplugged and turn it on its side and take the bottom panel off. The belt is in there. If it has snapped or frayed you'll need to replace it. I have a few belts that might fit. I would need you to measure the size though by putting a piece of string around the big wheel and the drive shaft and then tell me the length in inches of that string. I could then check my inventory and see if I have one that size. If I do I could sell you the belt. There are several videos on you tube that show how to put a belt on a bread machine and you could install it yourself.
Aug 19, 2011 | Sunbeam 5833 ExpressBake Bread Maker
Breadmaker kneader slips. Belt is fine.
here is the site to oder the part for your breadmaker
http://www.cuisinart.ca/cuisinart_parts_accessories.php?product_id=8&item_id=11&cat_id=24
Nov 28, 2009 | Cuisinart CBK-200 Bread Maker
Toastmaster TBR15 Bread Maker Logo
115 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
troup
Level 1 Expert
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
