Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Burning smell I have the same problem and an appliance guy came and checked it out and couldn't find anything wrong but it was doing it again the first load I tried after he left! Any idea about the burning smell????
Could be the motor getting old
Posted on Oct 05, 2009
I have a Kenmore H2E dryer model 110.87562602. I don't know what happen but smell burn. the panel control is working well but dont start
burning smell good be a lot thing wrong with your dry .if u know how to take front panel off are the dryer may have a bottom access panel be fore u do any thing unplug dry are turn the power be safe are call a appliance repair tech to fix the dryer for u ok .
Jun 13, 2017 | Kenmore Dryers
My dryer has burnt smell just buzzes but doesn't
Check the motor, it's sticking or already burned out
Mar 26, 2013 | Dryers
My kenwood gives out some strange smell as if the cables inside are melting when I start it. The last time I used it, I had to stop as it couldn't blend. Please help, its quite new!!
DANGER !!!
If ever you smell electrical burning, you MUST TURN OFF the device and have this checked immediately by an authorised auto electrician.
Failure to do this can turn into a possible car fire!
Mar 02, 2013 | Kenwood Car Audio & Video
Washing machine wont turn on or do anything
Hi
As I understand you, there does not seem to be anything wrong with the belt in spite of the burning smell. have you checked the fuses. Often there are small fuses that distribute the power to different parts of the machines, they are most often situated near or in the control panel. Check that.
good luck
Kolbrun
Apr 24, 2012 | Magic Chef CAV2000AWW Top Load Washer
My car smells like its burning oil, and there is oil in my spark plug wells. Guy at auto parts store says I need to replace oil gaskets that go around spark plugs. Is this a valid diagnosis and if so is it...
As far as I know spark plugs only have a metal type washer to seal, and there is no other oil seal needed. I have know oil to leak from rocker cover and fill spark plug wells, but tis also often covers engine. Burning oil smell couldbe from oil going onto the outside of hot engine. Check oil loss via dip stick. Clean all oil from outside engine to find out sites of leaks. Hope this helps.
Sep 22, 2017 | 2004 Volkswagen Jetta
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
Loud banging sound when dryer is on much like when tennis shoes are drying, smell a burned rubber smell when door opens
Sound like either your belt or your bearings. Either way, I wouldn't run it anymore until I got a professional appliance repair guy out to check it. We wouldn't want your house to burn down. Very dangerous!! I would also unplug it until then as well. Good luck and stay safe!
Jan 28, 2010 | Whirlpool Dryers
Model 63259 bought about 2 months ago. I went to
you can check and see if there is a fuse on the microwave, if not it may have just burned out, its probably still under warranty so try to take it back for a replacement
Jan 14, 2010 | Kenmore 63252 Microwave Oven
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
