Question about Dell PowerEdge 2300 Server
My problem is that I need a key to open the cabinet
  • 20 Answers
The Keys have numbers. Some are tied to the customer service number on the back of the case, IF it has been registered for warranty. If not...then you can either force the lock ( its pretty hard ), or drill they key out....or drill the case from the top. ( I drilled from the top, soft plastic, then switched to a metal bit, and drilled the metal tang off. Replacement cost: $4.75 for some black epoxy, $2.00 for the metal tang. ( comes off with a nut driver ).
Posted on Oct 04, 2009
I cannot find the keys. do all keys fit the model 3400 for that machine.
Yes the cabinet keys can be purchased and are the same on all (same)models, unless it was changed. These are not normally changed. OK that sounds like a Wurlitzer model number. Since you didn't specify, I'm assuming that you have a Wurlitzer 3400
It uses cabinet key # RW105
Can be purchased here for$6.99
http://www.needles4jukeboxes.com/Wurlitzer_Keys.htm
HOWEVER,
Cash box keys are always changed and are not available. You will have to pick it open, call a lock smith or drill it out.
Jun 09, 2015 | Audio Players & Recorders
Need Locks and Keys
Heres what you can do-
the face of the lock barrel or where the goes there is a number or a combination of letters and numbers
that is all you need to get new keys made by a locksmith-
Or now on ebay you find a locksmith and with the number he can cut a new key and mail it to you
Perry
Dec 10, 2013 | Craftsman Industrial 9-31013 - Rolling...
How do you pick the lock of a china cabinet?
I recommend buy a key for the lock of your china cabinet becausethere is a standard china lock and they only cost about $5. The reason I recommend this instead ofpicking the lock is because it is very easy for you to damage the apparatuswhen trying to open it. Your time andmoney would be better spent to just buy a new key.
May 29, 2012 | Furniture
How do I fix my computer moniter?the screen is black
When you power up then after 12 seconds check the num lock led status on key board press num lock key then if num lock led is on and off then your cpu is working fine.
For that make sure vga adapter from monitor is connecxted to cpu is properly.Then when you power up the computer press F8 key then you can see some menu enter in "Enable vga mode " then go to display property and change screen resolution to 1024*768 then apply and check.
But if num lock led is constant then then you need to open cpu cabinet cover.
Then reconnect ram memory .Try it in different ram slot.Make sure motherboard is not ground with cabinet.REmove pci or other card if any.
Then check.
Pull cmos cell from motherboard for 10 minutes then connect again.
Also reconnect processor and it's fan then check.
Let me know if you need further assistance.
Thanks for using FixYa.i
Jun 28, 2010 | Computers & Internet
My HP Pavillion keyboard lights up but the screen is blank what can i do?
Press num lock key of key board if num lock led is on/off then your cpu gives display to monitor Then make sure monitor cable is connected properly to cpu vga port.
When you power up the cpu press F8 key then enter in "enable vga mode" Then go to start->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
Then check.
But if num lock led is not on/off and left constant then you need to open cpu cabinet.
Refix RAM memory.Pull cmos cell from motherboard for 10 minutes.
Clean dust from all parts.
Reattach processor and it's fan.
Open motherboard from cabinet and try outside of cabinet.
Dec 24, 2009 | HP (D7580-60003) Motherboard
The seal around the front of the tub has a chunck missing. is this part hard to replace?
If it is a small hole, try repairing it with black silicon glue. Clean the area with alcohol first, and allow 24 hours for the glue to set up before use. If it does need to be replaced, it is glued to the outer drum (inside the cabinet) and also to the door opening in the cabinet. It's not hard, but is tedious to remove the old part, clean the old adhesive, use automotive contact cement (weather strip cement) to coat the rubber and tub faces first, set the boot in correctly (it should be keyed) after an initial drying period, the do the same with the outer rubber and cabinet opening.
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Beep codes
you check memory stick i mean extended ram surface clean with eraser or change ram
Sep 09, 2009 | Computers & Internet
MY GATEWAY 702GE DESKTOP TURNS ON BUT NOTHING HAPPENS. THE MONITOR WILL NOT TURN ON AND THERE ARE NO BEEPS.
First open cpu cabinet.
Refix yopur ram memory.
Then pull cmos cell from motherbord for 10 minutes so all settings of motherbord are defaults.
Then check .
If still face problem then remove all PCI cards from PCI slot.
Pull motherbord from cabient then check in outside of cabinet some times motherbord is grounding with cabinet.
Also pull processor and its fan then clean dust from all parts.
Also when you power up the computer press F8 key then go to diaply proeprty and change screeen resolution to 1024*768 .
Let me know if you need more assistanse.
Thanks.
Sep 02, 2009 | Gateway 702GE PC Desktop
I need to repair my washing machine Model KAWE577BWH1
To remove the cabinet safely, the washing machine should be turned off and unplugged. Next take out the control panel by removing the screws. Also take out the spring clips which are situated in the corners and after doing that remove the harness that is connected to the lid switch wiring. Pull the lid and also keep a hand on the cabinet opening that shows itself when you open the lid. Furthermore adjust the cabinets position and then pull the lid and the cabinet opening. It should be removed now.
Feb 18, 2009 | KitchenAid KAWS850LE Top Load Washer
Dell PowerEdge 2300 Server Logo
187 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
