Question about Kitchen Ranges
I have kitchenaid electric stove but my RHS element does not work. I want how open the top part of the stove
    President:
  • 1,304 Answers
Check to see if you have a burner selector switch up on the control panel
Posted on Oct 05, 2009
Kitchenaid stove code f68
This stove should absolutely still be under warranty. I would start with calling the KA customer service. They are pretty good and will usually do all they can to help you. The number for them is:
800-422-1230
Jan 03, 2014 | KitchenAid Electric Stove Range...
I have a KitchenAid Architect KESC308LSS Electric Range and the stove top works fine but the oven is no longer getting hot.
After having checked the fuses, it would most likely be the oven switch because it is unlikely that both elements would go at the same time. Mane sure that the main switch is off when removing fuses to check them!
Jan 16, 2011 | KitchenAid KESC308LSS Electric Kitchen...
KitchenAid electric range KERS807SSS02 -in the middle of cleaning cycle, NO power outage but panel went black and door remains locked even after cooling. Circuit breaker not the problem. Top elements work.
We have a Kitcheaid gas stove and have had 3 new thermostats installed. After the 3 time it finally did it's first full cleaning cycle.
So three service calls later, (first was after the warranty) and three thermosats and over $500 and the stove has done it's first full cleaning.
Lots of examples of this same problem but it seems no recall on the stoves.
Jan 08, 2010 | KitchenAid KDRP407HSS Dual Fuel (Electric...
One of the burners on my kitchenaid cooktop will not heat up. What do you think the problem is? Is this something that can be easily repaired?
If it is not a glass top stove, with the power OFF, and cold, pull out a working element of the same diameter and install it where the non-working element was. Try it now. If it works, replace the heating element. If it does not, check for voltage at the element connector. CAREFULLY. Worst case is that the switch requires replacing.
Dec 17, 2009 | KitchenAid 32 in. KECD805 Electric Cooktop
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
Oven elements dont work / stove top works fine
I just had a repairman fix my Kitchenaid 507KERCYAL0 electric range and oven. The problem was a $4.00 fuse. I didn't see exactly what he did but he accessed the fuse from the rear - had to pull out the range and I think remove a panel. Hopefully this helps and saves you $$. I ended up paying $90 to fix a $4 problem
Nov 28, 2007 | KitchenAid KERC507 Electric Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
