Question about ViewSonic VX2235wm LCD Monitor
PC turns on. Monitor stays black. If I turn the monitor on and off repeatedly, eventually it comes on but it takes alot of on and off tries. Tried an old monitor and it works fine so it is definitely my monitor. Not sure how to fix this.
  • 2,229 Answers
This would indicate that you need a new monitor.
Posted on Oct 04, 2009
Samsung external monitor turns on briefly then goes black
Most likely it is a fault with the external monitor, either an inverter circuit board or the CCFL lamp.
To confirm if the laptop video card is faulty, connect another external monotor to the laptop and if the monitor is OK then it confirms the Samsung monitor is faulty.
Mar 31, 2012 | Computers & Internet
Monitor doesn't turn on when computer turns on
step 1: try using different VGA cable
step2: uninstall and reinstall the monitor driver from the device manager.
step 3: check with different monitor in the house if its not doing the same then take my words that its a monitor problem and the monitor needs to be replaced.
May 06, 2010 | Dell E176FP 17" LCD Monitor
Like when i turn it on it stays on for 1 min and then the screen turns off. but the light is on
Is your computer turned on? If it is not providing any "signal" through the data-cable to the monitor, the monitor will eventually go into "power-saving" mode.
Have you tried connecting the monitor to a laptop computer?
If it works, then the monitor is OK, and your desktop computer is the problem.
Have you tried a different monitor with your computer?
Oct 27, 2009 | Samsung SyncMaster 920NW Monitor
HP vs19e Computer turns on Monitor stays Black. blue light blinks
Same here- I understand that the capacitors are bad and need to be replaced. I am going to undertake it myself. Radio Shack sells them.
Apr 08, 2009 | HP vs19 19" LCD Monitor
Backlight for display cuts out
Bad capacitors are a plague now, most likely cause of the black screen
simply remove the doomed and caps that have color leaking from the top. and replace with duplicate good caps from your local electronics store
Mar 22, 2009 | HP W2007 LCD Monitor
Montior Repeatedly Shuts Off/Goes Black
i have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Monitor black out
try to adjust the setting of your video and refresh rate
Mar 12, 2008 | Videoseven V7 R19WPS 19" LCD Monitor
Viewsonic monitor seems to be stuck in sleep mode
Sound's to me more like a Video card issue, try the monitor in another computer if you are able 2 , otherwise please make sure video card is in tight and secure , not 2 sure what you mean by sleep mode, are you using windows vista? or xp? you may need to change some settings on your operating system , when you turn on computer do you see anything on screen at the start up? also when you click the menu button on the monitor does anything come on the screen then ? if so then its in your opertating sytem settings , disply settings e.c.t, i really need more info to help you solve this , the best thing i can suggest for now is to try the lcd on another computer a friends computer maybe , before considering the monitor is toast , hope this helps some way , good luck !
Nov 16, 2007 | ViewSonic VA1703wb Monitor
LCD powers off and on repeatedly
Your monitor power supply is unstable and needs your expert attention. Check out for bad capacitors.
Apr 02, 2017 | Scanport GL 821A 17 in. Flat Panel LCD...
ViewSonic VX2235wm LCD Monitor Logo
184 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
