Question about Garden
Detergent fails to mix - Garden
What is an alternative to sae-30 non-detergent oil.
A two stoke oil is a non detergent oil and is mixed with the gas for two stroke engines. If you are looking for an oil to add to the crankcase of a four stroke engine, you are better off with a detergent oil, the detergent and additives are make to keep your engine clean by attracting the particles in the engine crankcase.
Jan 26, 2015 | Garden
What can I use to remove a stain of SOYSAUCE in a carpet?
Carpet
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
Laundry detergent not dissolving
If you can let hot water to mix more with the cold when the washer fills, that will help the detergent to dissolve. If that's not an option, you can heat up about two quarts of water on the stove and when very hot, turn down the heat and add your detergent, then stir it till dissolved, and then add it to the washwater and clothes.
Sep 19, 2012 | Fisher and Paykel Washing Machines
When my machine stops during a cycle what does F1 mean?
Long and short of it is you are going to need a new machine control unit (computer) the pressure sensor that reads the water level is failing. This is a known problem with these units,this problem will only get worse, The one thing I will tell you is make sure you are using HE detergent. One of the things that cause these computers to go bad is to much or wrong detergent used and it fills up the pressure sensor hose with soapy water that goes right into the computer and electronics and suds dont mix.....
Sep 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Questions on use of softener and detergent
softener goes in agitator cap. when machine does first rinse and spin it will dispence.i dont think so 4 detergent use, front loader detergent doesnt froth as much.see how u go and reply 4 more help
Apr 03, 2010 | Fisher and Paykel (IWL12)
Pressure washer will not draw soap from cleaning tank
I had similiar problem, be sure the detergent hose isn't clogged. Mine was clogged where the clear detergent hose entered the pump. I cleared the clog and it worked perfectly
Apr 04, 2009 | Garden
Smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Nov 08, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
How to add liquid detergent and powder booster at the same time?
any booster would go in the detergent dispenser,should not be a problem if you are doing warm washes.if you do alot of cold washes,check for build up and clean from time to time.
Sep 28, 2008 | Frigidaire Affinity ATF7000E Front Load...
Bosch aquatak 120i pressure washer/tetergent
Hi hope i can help!!
Try this empty the detergent tank then have your machine ready to work then half fill the tank with warm water and use the machine, this may take a few attempts so dont think its a 5 min fix! What happends is the detergent when left in the machine goes thick and gooy the warm water thins this and eventualy cleans it out but dont use boiling hot water this may damage the seals.before storing machine away do this method.
Hope this helps .Sean
Mar 02, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
