Question about Insignia IS-LCDTV32 32 in. Television
Sound The sound turns into a rainy sounding noise about 1/2 hr after turning the tv on.The remote will not work and the sound goes completely.
  • Lou 700 Dec 24, 2007
    The only thing I could do is vacuum the TV.I cannot go inside.
  • 4,102 Answers
Hi your problem is going to be a solder problem either caused by the unit over heating ie by the air vents being blocked with dust or a build up of dust around the amp part of the unit.
The first thing to do is get the schematics for your make and model try using search engine to search for one you should be able to find one.
If you fail to find schematics diagramme then take the back off the telly and follow the speaker leads till they get to the board then have a look around this area probably need magnifying glass to look properly.
You will need to check all resistors around this part of the board and also look underneath at the solder points on the board as your problem sounds like that it is getting hot then the solder is not connecting properly and disrupting the circuit.
But because of this all resistors will need to be checked around this area as the solder shorting and not giving proper connection this will cause resistors to blow check these for swelling or burning.
The chances are it is going to be a solder problem but this will need locating and re soldering.
But remember that a telly is live for 24 hours or more after you switch it off and unplug it so beware of this as a short could destroy the telly.
If you are unsure what you are doing please leave it to a pro as you could destroy the whole unit also you will need a good fine soldering iron and correct solder and make sure you only solder the bad point as geting solder on anything else will cause whole unit to short.
So please leave to expert if you are unsure as experts will have equipment to test the board and find where the bad solder is.
As the problem only happens after a short time then it is going to be a solderr problem if you need further assistance then let me know ok
Posted on Dec 24, 2007
  • paul proctor Jan 03, 2008
    Hi after researching your problem through a repair shop they said it will be a solder problem on the amp part of the circuit board because if it was a blown resistor then you would get the problem strait away when you turn the telly on but by what you are describing its happening after the telly has got to temperature and then overheated you will need to get this looked at if you are unsure yourself what you are doing as its difficult for me to talk you through it without having the telly in front of me but if you dont get repaire it could destroy the tellys board and then the whole board will need replacing
Tv no picture
It sounds like it's developed a serious fault, is it still under warranty or manufacturer return?
Jun 25, 2015 | Televison & Video
TV sound changes by its self goes to 100 or 0 randomly remote won't work
2 questions.
1. Do any of the remote functions work, IE. channel selector, settings menu etc.?
2. How old is the TV?
Several possibilities come to mind;
The remote battery is low.
The remote sound function may be faulty( bad button switch) this is usually a matter of how much the sound switch is used.
The automatic volume control in the TV has failed. This sounds like the best possibility. Once set, the sound should maintain its level. If not, the the AVC is dead and you will probably have to get the TV assessed by a tech. If this is the problem, you might consider a new TV. Tech service is expensive and in many cases it costs so much to fix a relatively simple problem, that buying a new unit is easier and more economical.
Aug 01, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Sir i have onida fgl 200.on rainy days some drops of water goes in the box,tv cannot start after that time...when i start it ,it gives some noising sound and no display image.after it completely off and...
the water has burned out one of the power supply parts to you tv it will need to be looked at and repaired by a service tech. considering it was just a little rain it shouldnt be an expensive repair
good luck
Aug 02, 2010 | Televison & Video
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Hitachi screen goes snowy and sound is totally distorted
Sounds like bad solder connect in tv tuner....can usually be
repaired or replaced.......................T.
Nov 30, 2007 | Hitachi 43FDX01B TV
Sanyo (0525390)Sound problem
What model of Sanyo do you have?
1.With the TV turned on point the remote and push the mute button.
2. Did the sound ever work? If so what happen before the sound stopped working?
  JR57Gard
Oct 21, 2007 | RCA RCU410MS Remote Control
Insignia IS-LCDTV32 32 in. Television Logo
26 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
