Question about Microsoft Xbox 360 Console
Xbox 360 immediately goes to 2 red rings (on start-up)
Originally I was getting 2 red rings after about 10-15 minutes of play.
I looked online for fixes, opened it up..tried some of the more sensible fixes, such as the 8 penny trick, but it 2 red ringed immediately after that. I took off the heatsinks and remounted them, and it still 2 ringed.
Noticed that the heatsinks were a little loose, so I added some washers and now it is really tight against the GPU & CPU, but it still 2 red rings 1-2 seconds after start-up.
I used regular heatsink paste, not the silver expensive kinda (does this matter?)
I did clean both the Chips and the heatsink, but the chips were almost impossible to get shiny like new, there is even some indented logos on the chip, so I figured the paste would fill in all the gaps.
I noticed that the GPU(or the one under the bigger heatsink) has two chips, do they need silver paste between them to work, (i.e. sense each other)?
I don't really know what to do, because it technically isn't overheating, I figured with everything on correctly, it's pretty impossible for it to overheat in a second, and when it does 2 red ring, nothing is hot.
I know about board warp, and my next step is to look for weak solder points and resolder if neccessary. ( I read one of the possible problem areas in near the AC plug on the board)
So the heat sinks are almost perfectly remounted, all the thermal tape is back in place(the 4 band-aids on the bottom of the motherboard) and it is completely free of dust. My power bar light is green when I power it on, so I figure that is ok. I don't know what else to do, short of buy another.
  • 2 more comments
  • imnotanumber Oct 04, 2009
    The heatsinks are on super tight, It would be almost impossible to get them tighter without breaking the motherboard.
    I know that's the obvious answer, and I'm telling you they are firmly in place, and even if they were slightly loose it wouldn't 2 red ring immediately on start-up.
    not sure why it spammed my comment 3 times, I only hit "post Comment" once. this website wants me to look a noob, I guess.
    Problem Solver:
  • 6 Answers
Temp sensor might be bad or there might be a short between the board and the sensor.
Posted on Oct 05, 2009
Heat sink hasnt been tightend enough
Posted on Oct 04, 2009
After 15/30 minutes of playing the first light starts turning red then the xbox crashes how can i fix this
That means there is a hardware failure. If you are in warranty, contact xbox at 1-800-4my-xbox and get it sent in to be fixed. Or you can try and fix it yourself with the self help guides online (search red ring of death fix).
Aug 30, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: red ring of death...
if you have one, two, or three rings, give the xbox a lot of time to cool down. If you have four, your xbox is fried.
May 18, 2010 | Microsoft Xbox 360 Console
3 rings of death turned to 2 rings. xbox 360 NEED SUGGESTIONS
you probably did something to where you messed up your xbox motherboard, making it (after less then a minute of power) get short circuited and power fails. i would recommend getting it repaired by microsoft if you have a warranty.
Dec 03, 2009 | Microsoft Xbox 360 Console
2 red rings playing for 40 min
2 Red rings is caused by the Xbox 360 overheating. This should not be happening after 40 minutes of play.
You can check your warranty status here.
If you'd like to repair it yourself check out:
www.xbox-experts.com
Nov 20, 2009 | Microsoft Xbox 360 Console
My xbox controllers will not charge with the plug in kit. The light turns red, then either immediately green, or it starts to blink red-off-red-off.
I had the same problem. The Battery pack on mine was dead for a long time as i havent touched my Xbox 360 in a while. So
SOLUTION
Step 1. Plug the play and charge cord into the controller
Step 2. If Light turns green within a minute or so, Unplug the play and charge cord and go to Step 1 (Repeating this process until the light stays red on the play and charge cord (3-10 times))
Oct 08, 2009 | Microsoft Xbox 360 Controller
Xbox 360 halo problems
my halo sometimes does the same thing when i start up the game but pressing a usually gets you through it, but if your xbox 360 overheats within minutes and is an older xbox 360 its usually a burnt out fan or just full of dust, if its old then ur warranty might already be out and if it is just open up the xbox and use an air compressor or anything else to get all the dust out of the xbox. in my case everything was just caked with dust. anyways... good luck
-Armand M.
Jul 24, 2009 | Microsoft Xbox 360 Console
2 red lights on the ring of light
your xbox 360 is overheating its called the red ring of death look it up on google you can have microsoft fix it if you still have a warranty on it, it shuts down so none of the components in the xbox 360 get damaged
May 30, 2009 | Microsoft Xbox 360 Console
2 red ring lights when playing World at War
no you still have a warranty microsoft extended there warranty due to console problems so call up xbox talk to max. and the warranty ends 2010
Mar 15, 2009 | Microsoft Xbox 360 Console
My xbox 360 has 3 red rings.I cant play my xbox 360 because of that red light?Can you help me?
Here is a linl to MS website. It doesn't look very good. Make sure the light on your power supply is green. Also, unplug the unit from the wall, wait a minute or 2 and plug back in and see if that helps.
http://support.microsoft.com/kb/907534
Mar 02, 2009 | Microsoft Xbox 360 Console
Red ring
check your AV cables
Jan 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
562 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
