Having problem with my comp. how you solve ''flush memory in command prompt? please help
  • 40 Answers
Go to command prompt and type the following command
ipconfig/flushdns
Posted on Oct 05, 2009
What's yowhen i try to start the comp. it tells me at the windows boot manager that i have the options to repair but if there is no disk call manufacturer because it tells me that the file ntoskrn
If you can somehow get to a dos prompt (black screen with white writing) then you can fix it without a repair disc or system disc. If not, just borrow a Repair Disc or Operating System Disc from a neighbor, friend, family member or co-worker. Just make sure that the disk is the same as your operating system. Look at your Certificate of Authentication (COA) Sticker that is affixed to you laptop. Most times it is on the bottom or inside the battery compartment. It will tell you which operting system you have and it will have a series of 5 letters and numbers which is your product key. If you have Windows Vista Home Premium, or Windows 7 Home Premium, or Windows XP Professional, then borrow that type of operating system disc or repair disc.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 23, 2012 | Computers & Internet
I can not sign in yahoo messenger always have error i have this problem 4 days ago and until i am trying to log in.. I been trying to un install the program but still the same. I can log in on e mail by...
try to flush the dns of your computer. Click start, all programs, accessories, then command prompt. In the command prompt, type the command" ipconfig/flushdns" , then try to log in to ym.
Jun 19, 2011 | Yahoo Messenger
I can't install w7 with 1TB brand new HDD, screen display boot MRg fairlured, insert system disk and press enter, what problem with my PC? please help to solve it. Thanh a lot.
Do Try these installation Procedure
1.) Boot from "WINDOWS 7" DVD;
2.) Select "Repair computer";
3.) Select "Cancel" to exit the repair wizard;
4.) You will now get a screen which displays 'command prompt','system restore','memory diagnostics',etc......
5.) Select "command prompt";
6.) Type your "DVD-DRIVE LETTER" in command prompt, press ENTER;
7.) Now if your Windows 7 is installed in C drive, type "copy bootmgr c:\" without codes, press ENTER;
8.) After successful copy type "exit" without codes, press ENTER;
9.) Reboot computer;
10.) Select "start windows normally";
Mar 24, 2011 | DFI 661GX-MLV SIS661GX CHIPSET SOCKET775...
I need to know my ip adress and all that stuff?? help please
Inorder to find the ipaddress of your computer follow these steps,
1. Click on start? Go to All programs? Accessories?Command Prompt
2. You will find a black screen which is the Command prompt
3. In the command prompt you will find a blinking cursor , there you type in "ipconfig/all" (without cotes)and hit enter.
4. You will find ipaddress, subnet mask, default gateway , mac address/physical address and all other information of your comp.
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | Computers & Internet
Have a toshiba satetllite laptop and i have error code 0xc000000f but was not givin a recovery cd and the old press f9 is not working. any ideas?
try going into safe mode with command line utility enabled. (F8 on bootup). in command console type chkdsk /f /r and enter y for yes at the prompt. wait for it to finish, it may take a while. If that doesn't solve it try typing fixmbr. If that doesn't work, manually load the os to boot from cd-rom. tap F1 while rebooting. in the BIOS go to boot options. in boot options change first boot device to cd. put the cd in the tray, save and exit your settings. The comp will boot from the windows disk. follow the prompts.
May 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
My dell inspiron 1525 has a memory write / read failure and i tried to reseat the memory and that did not work. Please help me
This could also be a problem with the hard disk. Part of the hard disk is usually used as a virtual memory. If the hard drive is defective, you could experience this kind of failure.
Check your hard disk drive using CHKDSK C: from a command line prompt. Check the outcome of this command. If you find any errors, run the command CHKDSK C: /F to fix the errors. Beware that the second command will prompt you to reboot your computer.
Nov 29, 2009 | Dell Inspiron 1525 Laptop Jet Black
It wont let me login please help
Try to use lower caps when typing http://www.facebook.com. Also, try using other browser, either Firefox or IE.
If that does not help, try clearing up your cookies and flushing your DNS. TO flush, you need to open a command prompt and type:
ipconfig /flushdns
Oct 07, 2009 | Facebook Social Network
Window is not running properly
type help on the command prompt and enter, and it will show the list of all commands.
Aug 08, 2008 | Microsoft Windows 98 for PC
Open Questions:
USA:AOL@ 1~866:201:6261 password reset CONTACT AOL Tec*h SuPp0Rt 24/7geniusmad*! Here USA AOL MAIL Tech support phone number help provide by AOL MAIL technical regarding your Issues call I~866~201 6261.AOL MAIL customer service phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL SUPPORT phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL tech support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Technical support phone number I~866~201 6261USA\CANADA AOL MAIL customer support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Support phone number I~866~201 6261USA\CANADA AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number
Jan 20, 2018 | AOL Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
