Question about Bose Lifestyle 38 System
Media center not working
I just set up the lifestyle 38 system, everything was working fine until I tried to instal the adapt IQ. Now the whole media center is not working, I can not turn it on or off, or get the DVD out. I tried taking out the power for 60 sec as it should reset but that doesn't work either.
Do you have a solution?
  • Sanke Dec 23, 2007
    I bougth my Bose Lifestyle 38 on Wednesday.
    I have same Problem, you have.
    I do not have a solution for our Problem.
    BOSE Lifestyle is standing on the display. That`s it.
    So I have to call the BOSE Service tomorrow morning.
    Best Regards Bernd
  • Anonymous Dec 23, 2007
  • 14 Answers
Be patient with the media center. It is processing a huge amount of information and takes time to complete.
First unplug the media center power at the plug in the rear. Leave it off for approximately 20 seconds. Remove the AdaptIQ head set plugged if it is still plugged into the AUX input.
Power the system back on. Leave it alone for 2 minutes while it re-initializes. After 2 minutes or so you can press the "Open/Close" button. It may take 30 seconds before the tray releases. Just give it the time and it will open. This is a common occurence after running AdaptIQ. For future reverence, after doing the AdaptIQ process, turn off the system "All Off" and unplug the headset then leave the system undisturbed for 10 to 20 minutes. After 10 - 20 minutes it will be ready for use.
Posted on Dec 24, 2007
Hi
can you please help me.How can I solve this problem.
The Media Center system doesn't work and the AdaptiQ CD (2) is in the Media Center. We can't put out the CD.
Posted on Dec 23, 2007
Can't link my new lifestyle 48 remote control to my lifestyle 38 system?
If the remote does not work as you expect
If your system does not respond when you press a button on the remote, it could be time to
change batteries. For information on the type of batteries to use and how to change them,
refer to "Replacing the remote control batteries" on page 51
In some buildings, you may experience "dead spots" where the remote control will not
operate effectively. If this happens, move the remote a foot or two and try again. Also make
sure the cord that connects the power supply to the media center (and contains the remote
antenna) is stretched to its full length and is separated from other power cords. If these
efforts do not work, move the media center a few feet to a location where it provides a better
response.
If the batteries are fine and the suggestions concerning "dead spots," above do not work,
you may need an antenna extender. To contact Bose
customer service to request one, refer
to the address list included with the system.
Source
Dec 31, 2013 | Audio Players & Recorders
Tip
Bose LifeStyle 38 Video Mode
Bose LifeStyle 38 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
_______________________________________
Bose LifeStyle 38 Manual Download
Reset Bose LifeStyle 38 VChip Password
on May 02, 2010 | Televison & Video
Tip
I hope that helps.
on May 02, 2010 | Bose Lifestyle 38 System
Software update failed 100 call bose
Hi Brian,
Did you get this sorted as I'm having the same issues?
Regards,
G
Apr 11, 2013 | Bose Av 38 Media Center Dvd Player...
I have just bought a lifstyle 38 and upscailer and i am strugglin to get it to work, i have conected all the leads to the back of the tv and connected a hdmi lead to the back of the tv and i carn't get a...
Depending on what series you have, you may have to install the VS-2 (Video Enhancer) Software on the media center (AV38) before you attempt to make a connection.
Most importantly, you have to connect the AC power adapter of the media center through the VS-2 enhancer and plug the VS-2's AC power adaptor into the wall. Hope these help.
Feb 19, 2011 | Bose Lifestyle 38 System
Bose lifestyle 38 has power but will not function at all. The display reads Bose Lifestyle - Try to turn on radio and nothing happens. Tried using remote for second zone and the remote display said no...
The sub is bad.the power supply inside the sub is your problem.If your unit comes on it could also be a defective dsp pcb in the sub.everything in the sub runs the head unit.If you send to bose they have a 175. flat rate.
Feb 12, 2010 | Bose Lifestyle 38 System
Bose Av38 Media center remote contro issue.
problems of conectivi betwen samsun and bose products many people whit same problem,
Mar 25, 2009 | Bose Lifestyle 38 System
Want to test to see if bose lifestyle 18 works.
Hi sorry but what do you mean that you have lifestyle 18 system? The lifestyle 18 system consist of the media center/DVD player, the bass module, the satellite speakers and the RF remote control (aside from tons of cables)
If you have the media center/DVD only, then you require the power adaptor. you can test if the media center is functioning if the LCD display is working. you can also connect an external powered speaker or an amplifier fro mteh AUX out behind the media center.
Do note that doing so will only give you limited control of the system since you require the whole lot to make everything work properly.
Glad to be of service.
Jan 27, 2009 | Bose Lifestyle 18 System
TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Dec 15, 2008 | Bose Lifestyle 38 System
Adding SA-3 amp
your media centre and sa-3 are from two different countries they work on radio wavs, if the amp and media centre are different they will never work sell the amp and buy one that is the same region code as your media centre
May 11, 2008 | Bose Lifestyle 38 System
Bose Lifestyle 38 System Logo
434 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
