Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The colors of my screen are not set and are split also the top and bottom of the screen are arched in towards the middle of screen how do i fix this
    Problem Solver:
  • 6 Answers
Sounds like a convergance problem needs to go in a shop
Posted on Oct 05, 2009
    Problem Solver:
  • 5 Answers
You have to open the TV. the silver screen on the inside might be loose and while its opened clean the 3 light bulbs it should also get a better picture to the TV
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
shaun
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba rear projection 42h81 convergence problem
In that case the convergence Ic's are defective or "leaking" they must be replaced. these are the TDA's
Jul 09, 2009 | Toshiba 53H71 53 in. Rear Projection...
The 3 colors are off, i have shadows and arches in the screen
It is failure of convergence ICs and these two ICs will be replaced on D board.
If you are comfortable with TV repair and know good soldering skills then can do the job easily.
Convergence ICs are mounted with sliver heat-sink on D Board of TV and part number will start with letter STK...
Get back to me if you need further info.
Jan 17, 2009 | Sony KP-57WS500 57" Rear Projection...
Can't set red convergence on 65" Hitachi
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Dec 24, 2008 | Hitachi Director's Series 65XWX20B 65"...
Green on screen
try to do it inside the board.
there are some adjustments except brightness and focusing..
try if you can ...
regards,
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Projection RCA P52940
sounds like it is most likely the convergence power supply board, if it were just one color It would most likely be the convergence board itself
May 27, 2008 | RCA P52940 52" Rear Projection Television
Which part(s) to replace?
If the screen looks OK after extended cooling is provided, you may just have a failed cooling fan.
Turning the blade with the power off will tell you if the bearings have failed or stuck, or just look at it with a flashlight to see if it is turning.
Check this first before you start replacing boards.
May 05, 2008 | Samsung HCN4226W 42" Rear Projection...
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
