Question about Kenmore 63942 Dryer
Push button and it doesnot start cheaked switch and it is good what could be wrong
  • 71 Answers
On the kenmore dryers you have to take the back cover off, should be 9 quarter inch screws and when looking at the back of the unit on the lint trap cover on the left there will be a small white fuse with 2 prongs this is called the thermal fuse. There is one quarter inch screw holding it on just remove the screw and replace the fuse and that will fix ya all up. You can call sears with your model number to get the part number and price, they usually don't go for more than $10. Number is 1-800-4my-home.
Posted on Oct 04, 2009
Maytag gas dryer mdg9306awa anits sounds like it wants to start but doesnot
that is the motor,try this,open the door,push the door switch in with one hand and spin the drum with the other hand while someone else pushes the start button,if by moving the drum the motor does start to run the motor is bad,also you have the neptune style maytag and i don't think there's a belt switch in the model so if the belt broke it could be jammed in the motor,try spinning the drum to help it start if that doesn't work unplug the dryer,open the door,remove the two screws that hold the door on and then remove the other two screws on the opposite side,grab the top of the front panel and pull forwards to remove the front panel,you can leave the door on or lift it up and pull out to remove the door,now look to see if the belt broke,if the belt is rapped around the center of the drum then it isn't broke and it will be the motor,that's a good dryer and worth changing the motor on it.
Jan 25, 2014 | Dryers
No clear sround sound from my receiver
ALL CONECTION +- CORECT ect cheak al wires on speakers and reciver cheak level use 0
Feb 09, 2008 | Denon AVR588 Receiver
It doesnot go after i switch on
Reset button on the back..push it with a tooth pick....
Mar 02, 2012 | Tomtom One XL GPS Receiver
1996 chevy 1500 z71. Keeps blowing fuse when trying to use push button 4 wheel drive. Note: 4- Low and 4-Hi stay lit and blinking before fuse blows. New actuator. New switch on transfer case. New transfer...
Cheak all wiring, one little **** in the wire will make a fuse blow. I had the same problem with my starter and i replaced the starter but it was still blowing the fuse, come to find out it wus a wire burnt into so cheak all wires carfully.
Nov 09, 2010 | 1996 Chevrolet K1500
No brake lights 97 ford f150 Also ABS light on dash blinking
thier is a switch on the peddle about 6 in up this may be pushed out of bracket or bad push button by hand if not it maybe bad abs could many things cheak wires to every wheel that fixed mine had broke wire
Dec 17, 2009 | 1997 Ford F150 Regular Cab
Car doesnot start
does any thing come on? if not you ignition switch is bad. and that will need to be replaced.
Jul 23, 2009 | 1999 Chevrolet Cavalier
Dryer won't start after I push the Start button
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 26, 2009 | Whirlpool Dryers
Neptune dryer does not produce heat md5500
Did you cheak for dead short by touching one end of the element and one end on the heater housing?if there is continuity then you have a dead short .The lint is normal just clean it out.You may have a bad insultor that the element runs true in the heater housing.Also cheak the wires for dead short very carfully with flash light hope this helped:)
May 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have a ge profile microwave. When I plug in the microwave, it's fine. As soon as I hit the start button, the microwave blows the HVT fuse. I assumed that it was the diode and the capacitor that were bad....
Another possible option would be to cheak the door micro switches . They can also blow the ceranic fuses.also how did you cheak the magnatron?Did you remove it complet and cheak over the ceramic end area if it was bubled?
May 15, 2009 | Microwave Ovens
My dryer will not start when button is pushed. There is a ticking sound in the back when I push the button to start it
Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
May 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
121 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
