Question about Haier HVF060A Wine Cooler
This wine cooler has worked great for 2-3 years, with the temperature varying by 2-3 degrees, i.e. 56-59 degrees. Today the temperature is room temperature, 73 degrees. Everything else seems to be working fine. I can't find the manual, in order to attempt to solve the problem. Would you have any suggestions?
  • kheagler Oct 05, 2009
    Yes, it is a Haier HVF060ABL. Are these mentioned repairs something that an individual, not electronically inclined, could do, or should I contact a professional?
    Thanks a lot for the information. I truly appreciate your help!!!!
    President:
  • 1,714 Answers
Can you give me a make, Is it a Haier?
Posted on Oct 04, 2009
  • 1 more comment
  • Craig Butler
    Craig Butler Oct 04, 2009
    The rotary switch is at the lowest temperature level, and it can not be adjusted by the rotary switch
    Analysis
    The rotary switch is failure, total current pass through the switch.
    Dis-connect the rotary switch from the main circuit. To ensure the switch is down, test it with a
    electronic multi-meter.
  • Craig Butler
    Also there is a fuse that may have blown in the electronics, you need to check it first. Nest, you need to check the control for the cooling...it is the thermistor inside the unit here is a photo...
  • Craig Butler
    Craig Butler Oct 05, 2009
    This is a little complex as far as circuitry goes. However, there is a fuse that could have taken it down. If you could look in the electrical system for a fuse, maybe you will get lucky. You could also just take a look at the connections and wiggle wires to see if it's anything obvious.
Manage my life com sears
It depends on if there is anything in it! Those types of coolers are only designed to drop temps of wine bottles to below room temp a few degrees. They don't cool like refrigerator in your kitchen.
Jul 22, 2014 | Vissani MCWC50DST Wine Cooler
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Where can I find a wine cooler that has 2 or more different temperatures zones?
there is a wide variety of dual zone wine cooler and theirprices range from around $300 up to $3000 and even more, depends on their and manufacturer. I recommend taking a slightly bigger wine cooler thanintended since once you have your wine cooler you start getting more and morewines and you'll end up with no room...just google dual zone wine coolers
May 29, 2012 | Furniture
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
Aug 01, 2009 | Avanti WC3201D Wine Cooler
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Oct 23, 2007 | Vintage Keeper VP500 Wine Cooler
Haier HVF060A Wine Cooler Logo
171 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Haier Furniture Expert? Answer questions, earn points and help others
