Question about Belkin (F5U237) 7-Port USB Hub
My computer does not recognise my Belkin 7 port hub.
My computer does not now recognise my 7 port hub. it was working before for a long time, but now not working at all
can you help?
kb
  • 3 Answers
Sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Posted on Oct 05, 2009
Does the F5U237 work with windows 8.1
It looks like Belkin stop support on certain models of Belkin, even thou you don't state the version model. But if you have a chance, visit this microsoft website which explain that it's not compatible with Windows 8.1
http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Name=Belkin%20N%20USB%20Wireless%20Network%20Adapter&vendor=Belkin&ModelOrVersion=F5D8053&Type=Hardware&tempOsid=Windows+8.1
Oct 19, 2014 | Belkin (F5U237) 7-Port USB Hub
How to download free driver for belkin F5U237
A driver is not provided by Belkin for this device. It should work with generic usb drivers found in windows or mac.
Feb 24, 2014 | Belkin (F5U237) 7-Port USB Hub
My belkin Hi-speed usd 2.0 7-port hub wont work and i cant find the CD that it said it came with. what do i do?
go to this site and download the driver for it. The CD basically contains the driver software. You can easily get it online.
http://download.cnet.com/1770-2014_4-0.html?query=Belkin+Hi-Speed+USB+2.0+7-Port+Mobile+Hub+-+hub+-+7+ports+-+desktop&searchtype=downloads
just select the correct operating system and install it on your computer. Let me know if you need any more help.
May 12, 2011 | Belkin (F5U237) 7-Port USB Hub
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
My OS is Windows Vista Home Premium edition. Will Belkinns 2.0 x 7 port hub F5U237v1 will work with it?
Yes it will definitely work it no matter what operating system your computer is using it will be working fine.
Nov 25, 2010 | Belkin (F5U237) 7-Port USB Hub
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
I can't seem to get the Belkin 7-port hub to work with windows 7. Whenever I plug a flashdrive into it, windows 7 doesn't give recognize the flashdrive.
windows 7 is a 64 bit OS, and still fairly new. A lot of drivers for hardware are not supporting 64 bit Operating Systems yet, maybe in the near future but right now a lot are not.
Temporarily or permanently switch to Ubuntu. I think this hub is compatible, and you can still read your Windows files in this Linux distribution.
Dec 30, 2009 | Belkin (F5U237) 7-Port USB Hub
One day the Belkin 7 port hub works the next day it doesn't
Your problems with the Belkin 7 port are not due to the Dell computer or the XP OS. To problem solve, select on USB port and stay with it, not the 2 top ports for your keyboard and mouse. 1. Plug in the power adapter, wiggle it about, widen the prongs, change outlets at the 120 v. end. 2. Use an simple hand magnifier and peer closely at the DC input plug and be positive that the center post and the minue side piece of metal if in firm constact with the plug. If cannot insure a firm fit, sligtly bend that tiny metal piece towards center. Option 2, use another adaptor with the precise voltage as the original and the idential pin that inserts into the module. 3. Use another or new USB connector.
This list does not imply a specific order of diagnosis. Your fundamental problem is the failure to delive DC power to the Belkin hub or to capture the hub to USB port signal. In a phrase, you gotta short somewhere.not an issue with the computer or the XP operating system. Bill Miller
Aug 25, 2009 | Belkin (F5U237) 7-Port USB Hub
My Laptop does not recognize Belkin 7-Port USB Hub(F5U237v1)
Try connecting it to another port or the one on the dock since some devices can be a bit picky about what port they get plugged into.
Mar 15, 2008 | Belkin (F5U237) 7-Port USB Hub
Open Questions:
See all Belkin (F5U237) 7-Port USB Hub Questions
Belkin (F5U237) 7-Port USB Hub Logo
957 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
