Question about Drills
Where can I locate a manual for a Central Machinery drill press model S-987. I need to know how to change the RPM settings. Which wheel gets moved on top?
    President:
  • 1,714 Answers
You just move the belt up or down for a ratio change.
Posted on Oct 04, 2009
Two more on the Ram Machinery drill press model no. 0019B. The table is on the opposite side of the base. Would that effect the tables levelness? And where can i pick up a replacement 5/8 chuck?
the table and the head should be over the base ( best balance for the unit )
chucks are available from a tool/ machinery tool shop
what you will need is what taper size it is
tapers are mores tapers and come in sizes 1 through to 5
probably need a no 2 morse taper chuck
Sep 19, 2016 | Drills
I am looking for a user manual for a Ram Machinery drill press model no. 0019B. Thank you
go google and type in ---user manual for ram drill press-- and download ant pdf versions
remember that many brands of drill press are all made in the one factory with just a different name so any drill press that has the same drill head operation will probably have the same user manual if you cannot find what you want
Sep 18, 2016 | Drills
I have a guardian power floor model drill press model FDM 58 12SP where can I find a 5/8 chuck
in perth i would try ron mac machinery sales.. in other states also machinery sales for trades or companies in steel work.. pete
May 11, 2014 | Drills
Central machinery model 586
are you talking about the 3 arm feed handle which are screwed in?? if you are you can weld it back in..pete
Jan 26, 2014 | Drills
How to replace blade for central machinery Model t-1582
This saw has been discontinued by Harbor Freight. However, you may able to ask from them a manual by sending them an email. Try to check this manual. Hope that helps.
Nov 24, 2013 | Saws
Chuck key
Go to a Harbor Freight Store or you might be able to get one one line. They have the replacement keys for the Central Machinery Drill Press.
Jun 15, 2013 | Central Machinery Mortising Machine
Power supply Delta DP350
If you go to http://servicenet.dewalt.com/ and put your model number in the search box, you'll be able to view/download the parts brakedown and owner's manual. You can order the switch from them or find an aftermarket parts place like www.ereplacementparts.com to get the switch.
Jun 12, 2012 | Delta Machinery Delta ShopMaster DP350 12"...
Porter cable hammer drill 987 suddenly stopped running.
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Mar 04, 2011 | Porter Cable 987 19.2 Volt Grip - To - Fit...
Parts manual
hi a bit tricky this one as far as i am aware ram no longer exist your best bet might be to try a want it now post on e bay someone somewhere is bound to have one ,even if you carn't get a complete manual you might be able to photocopy the pages you need best of luck silk090
Dec 16, 2008 | Drills
Drills Logo
849 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
