Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Heating element is white hot back by the connectors
  • 736 Answers
The heating element is shorted to ground at that point and must be replaced.. it is not safe to use it this way.. usually that will trip a circuit breaker .. if it doesnt then you might want to have someone check to make sure the correct breaker is used (in your fuse box) ... if it hasnt already done so, that fault can damage the controller and seals where the heater goes thru the tub .. a new heater comes with new seals but not with the parts required to fix the controller if thats been damaged ..
Posted on Oct 04, 2009
790.9422340A LEFT FRONT ELEMENT WON'T WORK
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 19, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Changed my Oven element, now top and bottom don't heat up
The bake element
Feb 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
Takes to long to dry. installed new heating element, new tstats and i noticed that there was a gap on the back gasket drum. this will allow air that is not heated to enter the drum causing a longer dry...
Worn gaskets will cause some extended run time, but 75% of the dryer problems I repair are directly related to improper venting. Check that first. Pushing air thru the clothes is just as important as adding heat. Vent connector in rear should be rigid metal or heavy metal flex. As short as possible with no kinks. An easy way to check vent is to look at element when dryer is running. Should glow soft orange, not red hot or white . Try it with venting attached and then removed. If element glows less brightly with vent off, then vent is restricted.
Jan 13, 2011 | Kenmore 500 6952 Dryer
Heating Element Failure
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Apr 03, 2010 | Masterbuilt 20070106 Electric Smoker
The dryer runs, but is not getting hot. Is there
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Bottom baking element remains on
From a consumer repair stand-point; I would inspect, test for continuity and or replace your oven bake heating element.
How to Replace an Oven Bake Heat Element: While ensuring power off when servicing; Remove (2) mounting screws and slowly back-out the element about 3" or so. Then, disconnect and remove wires located on each side of heat element; re-install new element.
Should problems still exist, contact me.
- C
Jan 27, 2009 | GE 30" Self-Cleaning Freestanding Electric...
HEATING ELEMENT IS RURNED OUT
You can order a new heating element from the manufacture. But, the crimp connectors and the thermo-fuse may also have to be replaced. You will need the crimp tool for the crimp connectors. You will also need a meter to verify the connections.
If you take the unit to an appliance center they can service it for you. But, you may find the cost of the parts alone to not be feasible.
Jerry G.
Jan 07, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
102 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
