Question about Sony Cyber-shot DSC-W55 Digital Camera
When I turn it on the lens moves in and out and turn and then on the screen it says to turn it off and then back on but that doesn't work. I can access my pictures but I can't take any
4 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: Turning the camera in off
Make sure your batteries are fully charged, and that both the battery and camera terminals are clean (use a qtip and at least 90% isopropyl alcohol).
That just makes sure you're not having a power problem. The most likely cause of this is for lint, dirt, dust, or sand to be inside the lens assembly, jamming up a tiny gear, and not allowing the camera to extend the lens. You can spray some compressed air into the lens assembly to try and free it up. The following website details the things you can try to correct this problem:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If this doesn't help, you may have gear damage, and have to have it serviced. Get an estimate first, since the cost of repair can be higher than that of a new camera.
Good luck, and hope this helps.
Posted on Dec 15, 2010
heatman101
  • 43501 Answers
SOURCE: Once the battery has been
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Posted on Apr 30, 2011
heatman101
  • 43501 Answers
heatman101
Lens doesn't work
Try removing the battery and memory card for at least 15 minutes. With some cameras, this will reset the camera and lens may clear the error message, as long as there is something that is not physically damaged the camera.
Jan 20, 2013 | Kodak Easyshare C195 14 Mega Pixels...
How do I re-set a 10.1megopixel c1033
Chances are something is blocking the lens. It could be a lens cap, or your finger, or even a grain of dust or sand.
Here's the best first course of action:
1. Turn off the camera
2. Blow sharply into the areas around the lens/lens cap.
3. Turn it on again and see if that resolves the problem. Be sure nothing is physically obstructing the lens. (No lens cap, no finger, etc.)
4. If blowing doesn't work, try using a can of compressed air like you would buy at an office supply store, and blow out the area around the lens and lens housing. Chances are, if nothing was obstructing the lens that you could see, it might be a bit of dust or sand. Even a little sand can totally screw up the lens and keep it from moving in or out.
5. If this doesn't work, you should take your camera to a camera shop and have it professionally inspected and cleaned. Check out how much this will cost, though, before you do -- it might not make sense to pay what they want to charge, versus just buying a new camera.
May 05, 2012 | GE C1033 Digital Camera
The camera was dropped while it was on. The lens is stuck in the open position. When the camera is first started it sounds like tiny gears spinning but not catching. It doesn't really grind or...
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon SD cameras:http://www../Device/Canon_Powershot_SD880 or
http://www..Guide/Disassembling-Canon-PowerShot-SD800-IS-Lens-Assembly/4093/1
Also you may try this Canon "Lens Error" troubleshooting guide >>http://camerarepair.../fixing-lens-error-on-digital-camera
6.To download the complete service manual for a similar camera model can be downloaded at the link below:
http://www../canon_powershot_digital_elph_digital_ixus.pdf/download.html
Wait 10 sec and click Get Manual .At the bottom of the page.
10_8_2011_7_21_11_pm.jpgCanon SD990 IS digital camera lens with ccd parts can be purchased from eBay >>PARTS-REPAIR-/140607486728#ht_483wt_1642
Oct 08, 2011 | Canon PowerShot SD990 IS / Digital IXUS...
I dropped my camera whilst the lense was out and everytime i turn it back on the lense doesn't move it just says 'turn power off and on' and i turn it off, turn it back on and it still says the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
Hi I am turning on my cannon ixy 700 and the lens is not opening up and i get an errror message on the screen saying E18 any help would be appreciated. Regards Leighton
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
The problem usually happens because dirt or sand get into the lens mechanism.
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Jun 21, 2011 | Canon IXY Digital 700 Digital Camera
My sony DSC H4 lens is stuck outside and it doesn go in .. the lens moves back and forth and is stuck ... the lens is also unable to focus.
Hi, Have you dropped your camera on the lens since I've seen that cause it before. If not then it's possible that the motor in the lens has gone. Either way it would be a costly repair which there's a 50/50 chance it would actually work again. Your best bet would be to get a new camera.
Jun 18, 2011 | Cameras
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
