Question about Fuji FinePix F10 Digital Camera
My camera lens does not open correctly. All
My camera lens does not open correctly. All pictures are over exposed and look white with lines. The video mode is working fine though?
jackboy
  • 2985 Answers
SOURCE: Camera powers down after lens comes out
Contact Fuji re this. if under warranty it will be replaced.
If out of warranty they may offer a discount on a replacement
Posted on Jan 15, 2008
zohail
  • 1223 Answers
SOURCE: When my camera comes on, the LCD screen is black. It's like the
CCD FAILURE !!!
Good news is u can always askfor free CCD replacement from FUJI i got it for S5000 even it was outof warranty and was not on service advisory list u have to call and askthem or email in ur region see the link for the problem
http://www.imaging-resource.com/badccds.html
if u are in U.S just dial this number
cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif+18008003854cb_transparent_r.gif
or just go to www.fujifilm.com and go to ur region link for support i am sure they will do it FREE OF COST !!
pls rate me FIXYA for help
Posted on Apr 02, 2009
zohail
  • 1223 Answers
SOURCE: Pictures are over exposed ( white ) in any mode.
CCD FAILURE !!! it starts with overexposed pics and purple and pink shaded pics dont worry
Good news is u can always ask for free CCD replacement from FUJI i got it for S5000 even it was outof warranty and was not on service advisory list u have to call and askthem or email in ur region see the link for the problem
Posted on Apr 04, 2009
zohail
  • 1223 Answers
SOURCE: Fuji Fine Pix s5000-Horizontal lines with purple coloring mixed
not a software issue it is
CCD FAILURE !
CALL Fujifilm they will do it FREE it is a known problem in thousands of camera i got my S5000 with same problem repaired FREE from FUJI just call them
BAD CCD
RATE ME WELL !
Posted on May 31, 2009
  • 244 Answers
SOURCE: whiteout on fujifilm f20. how do I remove the lens?
Firstly, to isolate the shutter as the problem, turn the camera on and the flash off. put the lens into full optical (not digital) zoom. Then turn the camera lens to face you and look at the lens and take a picture.
With the camera in full optical zoom the shutter assembly will be right up to the outer lens so you can see it clearly. When the button is pressed you should see the shutter fire across the lens inside. It should cover the lens completely. If it does not or doesn't fire at all then you get over exposed pictures or lines across the photo. The most likely cause for this is moisture residue on the shutter leafs sticking them together.
To clean you will need to strip the lens down almost completely to access the shutter assembly. If this model of camera uses a sealed shutter unit then it will be impossible to clean. The only models i have found so far that use a sealed unit are the F460 and F470. Yours I am not sure of as I haven't opened 1 up but the solution for most is to strip it down and clean.
Tip: use another camera to photograph each stage to help on re assembly
Posted on Jan 18, 2010
All outdoor exposures are white.
Sounds like you ISO setting (the 'film' speed) is set WAY too high. The brightness outdoors is causing the camera to not be able to expose correctly within the parameters of lens aperture and shutter speed. Try setting the ISO at 200.
Oct 04, 2015 | Canon PowerShot Cameras
When i take picture,the picture is white n some time become very very bright, but if take video is ok.
this can be usually associated with your white balance in still camera mode.
Check to see your white balance is set correctly or just set it to auto. Also make sure the mode you are in it set. (ie. indoor, outdoor, auto, speed)
May 04, 2011 | Canon PowerShot A460 Digital Camera
Over exposure white picture
hi,there's a problem in shutter that's why you hace over expose picture or line on the images if you zoom out.if you can open you camera and remove the lens unit. you can adjust the shutter or you can check the cable if its broken or not.
thank you
Jun 22, 2010 | Casio Exilim EX-S600 Digital Camera
When you take picture it comes out white
the picture is over exposed, try putting a filter over the lens to correct the exposure
Mar 28, 2010 | Samsung Digimax D53 Digital Camera
My pict from s500 show white lines, but that is nothing problem when use to recorder/cam record & candleligt fiture.
Unfortunately the shutter motor is broken, so normal pictures will be over-exposed. If you use it as a recorder or candlelight function the shutter mechanism doesn't need to work because the shutter is always open.
Fix that problem is very difficult, unless you get a new lens block.
Hope this helps,
Pablo
Jan 27, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
Konica Minolta Dimage E50 suddenly over expose. Indoor at night, the picture looks almost normal. Daytime the wall will be too white. Outdoor the picture is white out.
Hi!
The shutter cable inside the lens has broken - a common problem with the E50. The cable moves as the lens zoom so it brakes at some point and then camera isn't able to control the shutter - control the amount of light taken. If you look closely at the over exposed pictures, you will notice horizontal lines accross them.
The shutter or whole lens unit has to be changed. It is quite expensive, I believe it's not worth it. You can contact Sony / Konica - Minolta service center.
I work in a Sony / Konica - Minolta service center and have repaired a lot of these.
Hope this helps!
Tom
Oct 05, 2009 | Cameras
I cano not take outdoor pictures its all white
shutter is sticking so it over exposes photos . will need shutter or lens assembly replaced. it will have banding stripes in low light and white in bright light.
Apr 17, 2009 | Samsung L700 Digital Camera
When i take pictures, sometimes they come out with lines all over them.
shutter problem. put camera into full optical zoom, turn it to face you and angle it so that you can see into the lens without reflection. In full zoom the internal lens is right up to the outer lens so, even on a small lens such as this, when you press the picture button you should see the shutter close across fully. If it does not you will get either an over exposed or complete white out picture. Or lines across your pictures.
The shutter needs to be cleaned. There is grease in the camera for the moving parts and is probable that this is the cause for the error.
I have found this to be the case for fuji's E900, E550, F40fd, F470, F460, and a few samsung's as well.
Mar 08, 2009 | Fuji FinePix A400 Digital Camera
Pictures Becomes white (Excess Exposer or ISO)
I'm not clear about your last sentence. It sounds like you may have accidentally set the camera to use exposure compensation to over-expose the images. To reset this, see page 27 in your user manual. If you don't have the user manual you can download it here from Kodak. If you said in your last sentence that this is not the case, I apologize for not understanding you clearly.
If this is not the case, then the light meter in the camera may be malfunctioning, telling the camera that it doesn't have enough light.
1) Make sure the light sensor is clean. This is the lower of the 2 small light buttons on the front of the camera, to the left of the lens as you face the camera. If that doesn't help try:
2) Use a - setting in Exposure Compensation to under expose the images to compensate for the damaged light meter.
If neither of these help, then it needs to be sent in for repair, or replaced. (If the camera is out of warranty it is likely that the repair cost will exceed the value of the camera and you should simply buy a new camera.)
jc
Dec 28, 2008 | Kodak EasyShare DX4530 Digital Camera
White pictures
Hi
Sounds like either your CCD is defective and it's not recording the image properly or your lens aperture is stuck open and is over exposing everything.
Either way it sounds like you need the lens repaired or replaced.
We are an affordable digital camera repair business, if we can get your lens it would be about $70 install it for you and ship the camera back.
Good luck from Darntoothysam com
Thomas
Oct 12, 2008 | Sony Cyber-shot DSC-S750 Digital Camera
Fuji FinePix F10 Digital Camera Logo
71 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
