Question about Dell Latitude X300 Notebook
I can turn off the wireless adapter in the startup menu and then start the computer at which point i can run the machine, however when i have it set to on it delivers the blue screen of death This is on the latitude X300 does anyone know what could be causing this issue?
  • 3,940 Answers
1. Corrupt driver for the wireless card 2. Failed card
Posted on Oct 04, 2009
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
Internet barely works
Step 1:
Most of the programs running in the background of your computer start automatically during PC reboot. These applications were added to the Windows startup menu during default installation. However, you probably do not need all of the programs that are currently running on your computer all the time. This only slows down your PC and the reboot time. Fortunately, you can access the Windows startup menu and remove the programs you do not need to have running automatically. Turning off the programs shuts them down until you enable them again through the "Start" menu.
Go to the "Start" menu, type "msconfig" in the "Start Search" box and press "Enter" to start the System Configuration utility. Click the "Startup" tab in the System Configuration window. Uncheck the programs that you want to turn off and stop from running in the background. Click "Apply" and "OK" to save the new settings. Restart your computer.
Feb 24, 2013 | Dell Studio Computers & Internet
M50vc recover wireless
If the problem is with the computer, in the Tray Notification Area, right click on wireless icon and open Network Sharing Center, click on Change Adapter Settings, Is the wireless adapter enabled? In Device Manager, Network Adapters, Is the wireless enabled? Reboot the computer and the wireless access point by removing power and battery and plug in wireless, let it run the selftest, plug in computer and boot normally. You can always Reset the wireless access point to default settings
Nov 30, 2012 | ASUS M50VC-AP012C Notebook
Cant access wireless network
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Dec 01, 2010 | ASUS Eee PC 4GB Notebook
I've installed the NETGEAR WN111v2 - It says that it have connected to the internet. but i yet no internet is found.
Open your run option on the start menu, type in msconfig, run it. go to the startup tab. uncheck the box next to Netgear WN111v2 Smart Wizard.
Next go to the start menu, My Computer. Double click Local Disk (C:), double click Program Files, double click Atheros, double click ACU (atheros client utility). Select Options from the main menu bar. Select "Select Client Software". Choose Windows. Hit OK. Close atheros and you should be in business.
Oct 09, 2010 | NetGear WN111 (DHWN111100NAS) Pre-802.11n...
How Do I Close the Netgear Wireless Adapter Window
For that you have to disable startup.
For that press windows key +R key so you can see run then type in "msconfig" without "" then press ok.
Then you can see system configuration utility click on last tab startup and disable all startup or netgear utility then apply and restart computer then it not open at startup.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 04, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I am connected to a wireless server but the lap top will not connect to the internet
Does it have Internet connected to the wireless server? If not, you will see a yellow exclamation point within the wireless icon (assuming you are running Windows XP, Vista or 7).
Is it a public access point? Sometimes (Mc Donalds is an example) you will be redirected to their access page when you open up Internet Explorer.
Hopes this helps,
BReady
Mar 28, 2010 | Dell Inspiron 1545 Notebook
I just got a wireless n network adapter. for some reason, it won't work. the light is flashing green and when i tried to put in the installation disk, the disk wouldn't run, saying that it is a mixed media...
If the light is flashing but the disk does not start you need to go into system settings/console/startup and turn the "Disk" auto startup ON. It was set to off for me by default. Restart and it will install the update from the disk.
Dec 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless adapter not showing up in network conections,icon
This happened to me when I had to install a wireless router in my house using my laptop to initialize the network for the first time.
The start up software messed with my settings for wireless detection on my laptop. It turned off the automatic detect for wireless networks in the
"Wireless Zero Configuration"
(This has the settings for the 802.11 wireless adapters
i.e. the one that comes with the R4000 presario)
to get to this hit start>run...
and type in this:
%SystemRoot%\system32\services.msc /s
go to "Wireless Zero Configuration" and enable automatic startup
, if the service is stopped, start it.
hit the apply button to save your settings.
May 01, 2008 | HP Compaq Presario R4000 Notebook
Belkin N Wireless Router F5D8233-4 shuts down desktops with gigafast g wireless adapters
Make sure that the computers in error are set to DHCP for the TCP/IP properties. For the computers to see each other, the workgroup has to be the same on all of them. Each computer must have its own unique name.
For computers to be able to access each other, the computer's firewall has to be set to allow, or be turned off. The disk drives have to be set to share.
The router should have a NAT firewall. It should be turned on by default. As long as the NAT is turned on, it is safe to have the computer's firewall turned off and still be connected to the net.
Jerry G.
Feb 26, 2008 | Belkin (F5D72304F5D7000) Router
Dell Latitude X300 Notebook Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
