Question about Electrical Supplies
My shallow well pump just quit. When I engage the ell shaped switch at the side it just hums. I put an ohm meter across the motor and there does not seem to be a short or ground. Switch problem?
  • 8,404 Answers
Is it possible your motor shaft is stalled because of deposits in your pump?
Id suspect you have a failed capacitor. If it is huming, your pump is probably not starting for one of these two reasons. Dont expect anyhelp at the big box store. Rather, seek assistance from a plumber with well experience in your area.
Im sorry to hear your pump is not running. It certainly reminds us how much we rely and depend on the lowly pump.
Of course you could replace the pump ... be ready to part with $400.00.
I hope you get going soon.
a
Posted on Oct 04, 2009
Electric dryer not heating. was a little and quit completely. Thermostats, thermal ?, and heating element ohm out good. Any ideas?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Dec 10, 2016 | Dryers
My intertek infared heated quit heating as good as it was its model # sgh-500-1pc
https://www.youtube.com/watch?v=sTRP6kHqAFs What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Nov 25, 2016 | Dryers
Kenmore dryer elite quiet pak II
May 04, 2015 | Kenmore Dryers
Dryer quit won't start wife ran both washer/dryer same time put new breaker in still nothing?
Apr 18, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Hasn't been using quite often since 2006, but recently when tried , it won't start when powered on, how to check if sth was wrong ?
GOD IS GOOD !!!!
Apr 18, 2015 | Dryers
Model # GLEQ2152ESO will not start just humming sound when you push start button. Error code rE5
Apr 13, 2015 | Frigidaire Dryers
I own a kenmore. Elite model#795.77563600 and the display screen on the door shows E r. D H it work for a while and then quits
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Feb 25, 2015 | Dryers
It dose not work at all it quit
Sep 25, 2014 | Dryers
My kenmore 600 series dryer quit, makes no noises does nothing?
Jul 01, 2014 | Kenmore 600 7962 Dryer
When I turn on the pump the motor hums for about 30 sec. then stops. Cleaned out pump basket and put my hand in, did not feel anything clogging it. When I put my hand inside I can turn the impeller...
Most likely either bad start capacitor, or start windings. If it's the windings it's pretty much shot. The capacitor is either under the big metal hump protruding from the side of the motor, or in the tail end with the wiring. Either way it looks like a black or silver canister. If you remove or check the capacitor remove the wires carefully and discharge the capacitor by shorting the two leads. To check the capacitor you need a special capacitance meter or an analog ohm meter. Some capacitor testers give a reading, some just an audible tone. To check with a meter it has to be an analog meter. Set the reading for ohms, and set for the lowest setting, maybe 1 ohm, or 10 ohms. When you connect across the terminals you should see the needle flick upwards then slowly drop. This is only a generic reading but gives you an indication the the capacitor is functioning. If the needle doesn't move, then it's probably open (bad) or if the needle moves all the way up and stays, then it's bad (shorted out) if you get a reading needle flicks and drops, you'll need to short the leads to test again. Replacing the start cap is cheap ($10-$20) compared to a new motor. You can usually find a replacement cap at Grainger, a pool pump repair shop, or sometimes at a local pool supply retailer.
You can check the motor windings by using an ohm meter, but you must remove the power first. That means you need to physically disconnect the wires, not just turn of power. If your not familiar with this best to have a shop test it. Motors can have multiple sets of windings for different voltages, and start vs run.
Sep 18, 2010 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
