Question about Vacuums
Can,t make my rewind cord-rewind --How do you take the back off???????.SOOOOO------I can check the problem----need respond ASAP!!!!!!!!
  • 50 Answers
This is a tricky job and will require a new winder mechanism. Take it to a repair shop and ask for a quote.
Posted on Oct 05, 2009
How to rewind the power cord assemble?
The only way to rewind the cord assembly is to take the cord real out of the vacuum and rewind it and put it back in. There is no easy way to do it
Apr 29, 2014 | Miele S514 Solaris Electro Plus Vacuum
I have a kirby G7D ultamite, I recently replaced the switch, it worked for two weeks then it hasnt turned on since. Also I checked the cord, it has power going to it. Please respond asap thank you.
The switch has probably come lose, have you checked the motor to make sure it is good? Usually the cord will short out right by the motor assembly try to wiggle it while plugged in and see what it does, its most likely the cord I recondition kirbys and never have I had a problem with the actual vacuum only the cord.
Nov 21, 2012 | Vacuums
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
The cord on my electrolux Epic 6500 has been pulled too far out and will not rewind. How can I access the cord reel to rewind?
There are two keys holding the body together, underneath the bumpers on the side of the vac. With the bag door open these keys when gripped with pliers will slide forward to release the body panels.
Before opening the vac, gently push the cord back inside the housing.
2 possibilities:
If the spool rotates and allows the cord to push in , the body must be disassembled, and the cord winder removed and the spring reloaded. This is tricky work. you will need to wind the entire cord onto the spool, then load 3.5 rotations onto the coil spring for tensioning, then reassemble. It's a bit like working on a land mine of you're new at it. Wear safety glasses.
BUT if the spool is locked from the outside and the cord wont push in or pull out, a fine , long blade screwdriver can be inserted diagonal to the body through the cord slot and with luck you can lift a cog of the spool releasing tension and the rewind will work. try that first , but be gentle . You must release the cord spool allowing a a dog ear catch cog to release inside by gently lifting upwards.
Post back to say how you made out,
Or look for an AERUS Electrolux service shop.
Sep 27, 2009 | Electrolux Epic 6500 Vacuum
Cord rewinder on a Electrolux model C102J vacum cleaner
Hi there Johnd, SmartAlec from Nelsonvacuums.com.au here. I fix vacuums full time for a living and the first time i had this problem with the australian version of this vacuum it tok me an hour to pull it apart and back together. now i have done a dozen or so it is about a 30minute operation. I dont know what you rate your technical skill level at but i give this machine a 8/10 for hardness. It is most likely that the cord has jumped off the reel and is wedged so it shouldn't require parts but it cant be done without nearly stripping it down. There is no reset or similar for the reel. My advice unless your very confident take it to a repairer. It would be 1/2 - 1hr of labour charge only i would think.
Hope this helps.
SmartAlec
Sep 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Automatic Cord Rewinder is not rewinding anymore
I had the same problem - the power cord for my Hoover Elite Upright (U5507900) was stuck a few inches out and wouldn't go any further. But when I unscrewed the rewinding mechanism, the cord had clearly gotten twisted and partly buried under itself so after some work I was able to free it. Now it seems to be working fine, at least for the moment. Note that I had to use small screwdrivers to unscrew the cord rewinding compartment, like the kind of screwdrivers you use for computer repair.
HTH!
May 27, 2009 | Hoover Elite Rewind Bagless Upright...
Lux 5000 vacuum cord will not rewind it is pulled all the way out need to disassemble
This rewind is not easy to work on, I rewound my Eureka with much persistance. The vacuum shop didn't want to tackle this.
It's easy to cut your fingers on the spring.
Apr 25, 2009 | Vacuums
Auto rewind for the electrolux oxygen 3 ultra
HI
If this isnt working correctly, take it back. It wont get better
Feb 20, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power cord won't retract on anaerus 5500 vacuum cleaner
What you can do is take out the six hex screws on the bottom of the machine while on it's back. When all the screws are out, flip the machine back over, making sure you don't lose any of the screws. From there, open the bag cover and leave it open. Remove the cord release button. (The big rectangular button near the rear of the machine. Usually a firm pull up will get that thing out without incident.) Grasp the handle with one hand and hold the machine steady with the other. With a firm pull, pull upwards. This should seperate the chassis from the main cover.
With the machine guts exposed, place the main cover on the side for now. Now, this next part you can do one of two ways. You can either leave the cordwinder wires attached, (there's only 2 connected wires to the cordwinder, the white and black. Black is on the inside prong while the white is on the outside) or you can take the wires off. I find it easier to disconnect the wires.
Now, remove the cordwinder from it's place, making sure you take note of how the cordwinder rests in the groove from the motor. From there you can rewind your cord fully. Once this is complete, continue winding the cord while holding the cord in place. Take note of the spring. Make sure you are winding in the direction that is TIGHTENING the spring. Make sure you don't overtighten as the center plastic piece will surely snap due to the overtension. This may take a few tries, but be patient. Once you have met your estimated tension needed, replace the cordwinder, put the cover back on WITHOUT SCREWING IT BACK IN PLACE and replace the cord rewind button.
Replace the large cord release button and pull your cord out at least halfway. Hit your Cord rewind button. If your cord rewinds fully, congratulations, you got it in one try. Replace the screws and you are finished. If not, re-open the machine and continue rewinding the cord in the direction that TIGHTENS the spring with emphasis on overtightening. Once you break that center plastic prong, you need to buy a new cordwinder, so emphasize patience. If you're getting frustrated, go take a break and come back. Repeat until the cord winds fully, replace all the screws and you are finished.
Apr 20, 2008 | Electrolux Vacuums
Vacuums Logo
123 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
