Question about Speed Queen Washing Machines
Aggatator does not turn fast enough during wash cycle or spin fast enough during spin cycle
  • Anonymous Mar 27, 2014
    looks like the nylon slip joint at the bottom is spinning real fast and the noise is when it comes off of the cam portion of the joint.
  • 6,784 Answers
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Posted on Oct 04, 2009
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Mar 18, 2016 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
Washing machine not spinning fast enough and
Check motor capacitors. Check freeness of the drum rotation, if you suspect clutch
Apr 02, 2010 | Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washing machine won't spin or aggatate
We had the same problem and it was really easy to fix. On the dial for the load size, turn it all the way to the right to "reset" and then check to see if it resolves the problem. It did with our washer same model and problem. Best wishes.... Doug
Jun 08, 2009 | GE Washing Machines
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
